hello i just have a few questions on the hicas on the r33s please and really need some help cause im having a bet ith a mate an i want to win
what is hicas (is it like 4 wheel steer)?
how does it work?
what models is it on?
yes its 4 wheel steering
has a steering rack acting on the rear wheels moves them about 1 degree i think at speeds over 80 kmh (some one will correct me if im wrong)
models? lots but not sure wich ones exactly but my R33 GTR has it!
hicas is short for Help I Cant Actualy Steer joking sorry lol :D got no idea what it means. :P
https://www.sau.com.au/forums/topic/233571-hicas/#findComment-4094971
so if i turn my wheels on the ground i will see the rear move?
https://www.sau.com.au/forums/topic/233571-hicas/#findComment-4094994
found this...
HICAS (High Capacity Actively Controlled Suspension) is Nissan's rear wheel steering system found on cars ranging from the more recent Skyline and Z iterations to smaller models like the Nissan Cefiro (A31), 240SX/180SX and Nissan Serena/Nissan Largo. It is also found on models from Nissan's Infiniti division, such as the Q45 and the M45/M35. Unlike other four wheel steering systems, HICAS and Super HICAS are fitted to improve handling rather than as a parking aid.
Earlier HICAS versions used hydraulics to steer the rear wheels. The hydraulic system was powered by the power steering pump and used speed sensors to determine how much and in which direction to steer the rear wheels. Later versions, called Super HICAS, moved to an electric actuator for the rear steering rack, making the system much lighter. The Super HICAS system also used its own computer to control the system instead of speed sensors. HICAS and Super HICAS rear wheel steering is limited to about 1 degree in either direction.
HICAS was introduced on the 1986 Skyline GTS coupes (GTS, GTS-R, and GTS-X). The system was later adapted to work on many models in the Nissan range, beginning with the Passage GT.
HICAS is the acronym for Nissans rear wheel steering system named High Capacity Actively Controlled Steering. HICAS works using different sensors which calculate speed, steering angle and corner position the rear wheels are steered by a maximum of 1 degree based on these measurements. HICAS helps eliminate body and give the car a more nimble fell, it does it job well and is helpful for the average driver who doesn’t push the car to its limits.
On a racetrack however HICAS becomes to intrusive and unpredictable, particularly on long high-speed corners, counter-steering is often needed to correct the Skyline though the corner, this is not good for lap times. Race team’s usually use a lock bar to disable the HICAS system which improves the Skylines balance, resulting in more predicable handling and faster lap times.
Earlier skylines (the R32) used a hydraulic system which had speed sensors and used the power steering pump to steer the rear wheels. The newer version named Super HICAS was used from the R33 onward; electric actuators were used a long with a onboard computer, this version saved weight, and is said to be a much improved system.
Edited by Buddy
https://www.sau.com.au/forums/topic/233571-hicas/#findComment-4095310
^^ From what you found, which I think is from Wikipedia.
In short, the HICAS helps with turning.
From what I read, as you turn a corner while traveling over 80km/h the rear wheels will turn 1 full degree in the opposite direction in order to help the car turn "Better".
If you are not use to the HICAS, you will feel the rear 'kick out' abit.
Its just to assist you in turning at high speeds but a lot of ppl dont like it as it can be an annoyance, like I said you can feel the car kick or helping you to drive towards the turning direction and sometimes you might end up over steering.
I do believe they came standard on GTR's only.
https://www.sau.com.au/forums/topic/233571-hicas/#findComment-4095704
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
