Hello folks,
Just thought I would post up some pics of the ceffy sitting in my mates back yard with the rims of my silvia (which is still for sale BTW only 8k!).
Also fitted my beloved Zeta from my original ceffy, and RX7, and silvia, and now the new car :P
Stretched tires and camber to come for the rears to try and squeeze them under the guards...
Enjoy.
post-18824-1219828160_thumb.jpg post-18824-1219828203_thumb.jpg post-18824-1219828293_thumb.jpg post-18824-1219828331_thumb.jpg
Edited by konect
https://www.sau.com.au/forums/topic/233596-k-o-n-e-c-t-s-c-e-f-i-r-o/
  • Replies 69
Posted Images
why did you remove the enkei's?
looks boro with those rims.. but
at the same time it looks tough as
like when you're in northbridge on a week night n u see some dirty whore walk past you wearing.. not much at all
but even still...
...you sitll have a look..
Im going to have to disagree with you bro. I did the whole body to suit the wheels haha :P
But you know, what do I know, I just brought a brand new HSV GTS :laugh:
JK
Oh I hate you soooo much :thanks: They are hella sexy.
I think that if the enkei's were a better offset they would have suited better. I planned to get BeeR rims but seems they don't make them anymore :S
R32's and Ceffi's share the same chassis yes?
they're about as similar as apples and oranges. totally different chassis. you'll never get a ceffy cage into an R32 sedan (ceffy's interior is much larger)... unless you chop chop, which kinda defeats the purpose of a cage.
Yeh they are fairly different. R32 cage should be easy to find through importers. I am going to keep the back seat but have to trim the seat a bit on the side.
In other news I had it dynoed yesterday and made 192kw @ 13psi with safe A/F so Drift Attack here I come :D
Done injectors or FPR yet?
Hope you still have my sexy Fuel Pump wiring in the boot :rolleyes:
JK
Hahaha not at the moment. I am going to do Injectors, AFM and remap at the same time and up the boost.
ROFL at the sexy fuel pump wiring! Drove it around yesterday...crossed a train line, BA BOW...car rolls to a stop, Ryan proceeds to swear at the fuel pump wiring. Had to get out and fix it in the rain.
What was the idea behind the wiring?
Fuel Pump Wiring - I had an issue where the ground signal from the ECU to the Fuel Pump Relay wasnt happening, so I use to ground the Relay to the chassis manually, ie DIY immobilizer haha (note spade connector swinging from the lock)
Then I eventually redid the wiring and ran a new speaker wire from the ECU to the boot (wire crushed somewhere obviously) and that was fine, and then I decided to run power straight from the Battery to the boot. After doing that the 040 sounded alot healthier in the tank, and the car ran nicer LOL. It had a wild flat spot and it dissapeared with more voltage in the pump.
Any other quirks you want to know about haha?
JK
Haha yes a few things:
1. What is the reason behind the switch under the dash that seems to be connected to the EBC?
2. Why was the trim piece for the rear of interior roof lining removed?
3. Who fitted the cage?
4. What was the reason for swapping the position of the AC controls with the HKS gauges?
5. Did you ever notice that there is only one gauge adapter on the oil cooler sandwich plate? What the heck!
6. Did the car have front indicators when sold by you?
7. What kind of oil did you run it on?
I think thats all off the top of my head. Got new tires all round for Drift Attack and changed the oil with some nice Syn 5...does excellent skids :thumbsup:
Ryan.
  • 5 months later...
1. I never had an EBC ... so I dont know! Chris's handywork
2. Im not sure where it went. Possibly lost it when I gutted the interior to take the sunroof out for the repair of the sunroof
3. I brought a full cage for it but never fully bolted it in properly. Chris's handywork?
4. So that you could see the guages more easily without having to tilt your head right down to see them.
5. No there is 2, one has a bung in it. I put it in too tight and couldnt ever get it out again, hence why i had oil temp going to the sump plug as my guage sender was too big to fit into the sandwich plate
6. Yes it had front indicators, they were clear too!
7. Mobil S 10w30 i think.
Hows the diff holding up? Best free gift that came with that car :P
PS sorry for the late reply - i dont peruse these forums much anymore since Im in the outter with my 09 HSV GTS Twin Turbo :D
JK
I think thats all off the top of my head. Got new tires all round for Drift Attack and changed the oil with some nice Syn 5...does excellent skids :D
Ryan.
Hows the diff holding up? Best free gift that came with that car :D
PS sorry for the late reply - i dont peruse these forums much anymore since Im in the outter with my 09 HSV GTS Twin Turbo :)
JK
Thanks man :)
I demand more information on your new car :down: It is still a 4 door hahaha
Update for those that care:
Cleared the RWC yesterday and going in for rego inspection on Tuesday. I'm the most excited I have been in a long time! Can't wait to be able to drive on the street again without a permit :)
Edited by konect
    • R32 pics Not sure if you can upload pics directly, but i've added them through an imgur link above.
    • There’s a possibility that Infinity G35x front hubs may be compatible, but it depends on the exact fitment. Sometimes, parts like hub and bearing assemblies from different models can work if the bolt patterns, bearing sizes, and axle specifications match, but the G35x hubs typically have a different design. It's worth checking detailed specs (like the number of bolt holes, size of the axle shaft, and bearing diameter) to compare, as Rock Auto does list some parts that cross over across different models. If you're going for a pre-pressed hub and bearing unit, that could be a good option. These units are usually easier to install, as the bearing and hub come pre-assembled, but you’ll still need to verify fitment, especially the outer diameter of the hub and bearing dimensions.
    • Love the input man! Defo gonna check it out
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
