Item: ISC 52MM ALUMINIUM RADIATOR
Age: BRAND NEW
Condition: BRAND NEW
Price: $270 DELEIVERED
To Fit: (What car) R32 GTR
Contact: TONY 0412862091
Comments:
HI GUYS
i recentely worked out soemthing with ryan from ISC performance like more of a swap thing for my n1 headlights so in the deal he gave me this aftermarket 52mm radiator, but im not in need of it as i already have an aftermarket radiator in my gtr, these retail at $299 and plus delivery another $35 so that is $334 but here is one going for $270 deleivered, i really need the money to cover my other stuff for my gtr but i havnt even yet receieved it from ryan as it wil be sent off tomorrow arvo but will be ready on tuesday or soemthing but guys this is a bargain and it is brand new so someone grab a bargain and take this aftermarket radiator,
these radiators are excellent for street and especially for any track work, they will keep the car cool with less overheating from up to 20-30% so heer it is guys and yous should know what they look like guys,
thank you very much and pick up is available from northern suburbs in melbourne
cheers tony
0412862091
Edited by GTRBOS
https://www.sau.com.au/forums/topic/233692-isc-52mm-core-aluminium-radiator/
Age: BRAND NEW
Comments:
HI GUYS
cheers tony
0412862091
Hey dude
Im intrested in the radiator would you ship to Perth?
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
