Had it tuned on Sat.
HKS GT-SS's
Sard 800cc inj
Nismo in tank pump
Z32 AFM's
PFC
CES dumps, 3in twin front pipes, 3.5in cat back
Jim Berry clutch
JJR intercooler hard pipe kit
Made 361awhp @ 18psi
feels gooooood. :(
Edited by Andy D
https://www.sau.com.au/forums/topic/234192-260rs-with-gt-ss/
HKS GT-SS's
Sard 800cc inj
Nismo in tank pump
Z32 AFM's
PFC
Jim Berry clutch
feels gooooood. :huh:
good stuff. post up the graph?
Thought about cam gears, but I like the fat low-mid range and am not really chasing peak power. Not sure if they'd make much difference for what I'm after.
Yeah, it was Stu (and friend) who installed all the parts, and did the tune.
He did an awesome job, and is a top bloke as well. I couldn't thank him enough.
Hey Guys,
i got my 260 tuned the other day after running it in after the rebuild.
Basics of the work, full forged internals, sump and rocker baffles, oil restrictor, Sard Injectors, malpassi fuel reg, in tank walbro feeding 2 litre swirl tank then to 044 bosch external, Garrett 2860rs-5 turbos, ems 8860 computer running 20psi it made 420rwhp (313rwkw)
Need to get a set of splitfires to increase the spark then we'll wind it up to 22psi and hopefully reach mid 320's at the wheels, that way completely ensuring it has 300awkw.
congrats on your newly acquired power. How much did you spent on total?
I was planning on the same mod myself but i have to scrap it cos im being restationed overseas. Will have to wait till i get back in oz.
How does the Jim berry's clutch feel? Any hard slamming like a sledge hammer?
Yudy
Very nice work Grim. How did you manage the rwkw figure? (front driveshaft out?)
Jim Berry clutch is a rebuilt factory item. Slightly shorter travel than standard but really smooth (wife can easily drive it).
Nice work guys. It inspires me to begin the mods to mine :)
How do you find the GT-SSs? Not too laggy?
From my knowledge, the GTSS is just right for it. Probably you are refering to the GTRS. That will be too laggy.
Yeah I know the GTRS is laggy as all hell, but the GT-SSs are still going to be slightly laggy. I was wondering how they compare with stock turbos. I really wouldn't want much more lag than stock. The stockers can support another power for what I would want, it's just a shame the turbine wheels are ceramic, otherwise I'd keep them.
Hey Andy,
Yeah dropped the front shaft and pulled the fuses then ran it in rwd as my tuner only has a rwd dyno, waiting to sort a few things then will drop it back into 4wd, i must say, 313kw in rear wheel drive is ALOT of fun though, the "wow did you see that volvo go sideways" looks i get are pure GOLD! :D
Mine with the 2860rs's isnt too laggy, real boost starts to come on by 3500rpm, then acheives full boost by around 4200rpm, so it comes on fairly hard. Its even more fun when it hits peak torque around 6000rpm and breaks traction in all but 5th gear! lol!
GT-SS's feel like they spool up just as fast as the stockers. Don't have exact rpm numbers, but by seat of the pants they are very impressive. Almost feels like a big cube NA motor.
My old RB20 with 450hp bb turbo, had lag. These are light years ahead.
Do miss the sudden boost hit and manic wheel spin though, (damn ATESSA, sometimes i wish i had a switch to turn that off)
Hmm been reading this with interest as i went for the 2860-7's as i wanted the response (there the same as GT-SS??). I wanted 300rwkw with them, might get it. Mine's a built motor with cams, so hopefully be responsive. Will know shortly.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
