so chuckin on some nismo afm's on the gtr this afternoon so will the car need a tune? it will cop one regardless next monday, but will it be right for the week before that or should i just hold off till then? cheers guys!
https://www.sau.com.au/forums/topic/234209-new-afms/
what ECU?
if your using an apexi powerfc you can select the VG30 afms from the AFM menu and your all set for the nismo items
the car will be fine on base tune to drive around, avoid thrashing the pants off it, but normal driving will be fine
if its another ecu then just baby it around until you can get it fully tuned
https://www.sau.com.au/forums/topic/234209-new-afms/#findComment-4104069
