Ok so i am definatelly going to be transplating an RB of some sort into my MR30 skyline.
question is which one?
and RB20DET is around $2100 for engine/gbox/loom/ecu
as opposed to an RB25DET at more like $4500 for the same
have your say on why i should should not go with either one of these
https://www.sau.com.au/forums/topic/23422-which-should-i-get-engine-transplant/
I say go the RB25... I love the mid-eighties Skylines, and to see a modded RB25 in an MR30 would be the dogs bollox... I guess I say that coz the RB20 was introduced in the R31, the R30`s replacement. But to have an engine from 2 generations up, would be the best old/new mix IMO. More power and a newer(ish) engine than the RB20 goes without saying.
cool thanks keep them comming, i really want to knowwhat ppl rate the engine as. i would only be looking at the ECCS R32 RB20 if i was to get one of these.
the car will also be changing, get rid of the pimp chromey, run some gold P1s and a front bar that i am hoping is getting made right about now
show your thoughts
yeh but why is the box so much more expensive than the R32 box like $1000 more ($250 as opposed to $1250)
ive got some import DR30 taillights on the way and a JSS front bar comming eventually
RB25... i personally didn't like the RB20 a great deal.
and my gearbox is going along quite fine with over 200rwkw... Nothing wrong with it yet lol
I'm not sure if it's a 20 or 25 box, but it's lasting good.
touch wood.
where ya getting a 25 from?
(mine might be for sale for the right price...)
Hmm, in an MR30 I'd be inclined to fit an SR20DET myself. But of the RB25/RB20, I dunno, if you bought the rb20 you'd have more money left to mod it, if you got the RB25 you'd have a slightly better base to begin with.
Too close to call. The RB20DET is more bang for your buck, but the RB2DET is definitely a superior engine.
cheers,
floody
Dude i thought about the SR then went nahh alot of work. Doh! just realised that instead of using the Skyline crossmember us a pintara crossmember... piece of piss!
why didn't i think of that!
i can get heaps more stuff for SRs and the like
can i change the poll to include an SR?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
