I'm just fiddling around with my current R34.
But yea, i'm after yet another R32 lol. This time though i'm spending some more time looking for a non-disastrous ending. Third times the charm haha. But I am contemplating buying a AE86 instead, not sure yet.
I'd buy your R32 Shane as that'll save me respraying it red in the future, but unless your willing to take organs and one testicle as part payment, I think I better start saving some coin. :)
Yea I thought they would be the same as well, but I saw on yahoo japan a set of extractors stating they only fit R32 not the RB20 NEO. Confusing I know.
Shane, i'm not planning on buying a AE86 from here, as I think some of these owners want ridiculous amounts for a 20+ year old rust bucket. You do get occasional get cheap ones popping up in Japan, and will source one if I go down this route.
And yea my R34's a little 2L. Slow as hell, but gotta love the sound of N/A. Just looking at minor tweaking on it and not keen on turbo conversion. Just want to keep it a daily reliable and plus i'm sooooooo over turbo's.
Edited by Chang
didnt know they made a rb20 neo....
i would of thought they would be the same. The rb25 and rb25neo are exactly the same bolt pattern wise, for both the inlet and exhaust side.
Slightly off topic - They did make an rb20 neo for the R34 - But they will not import it into Australia becuase it does not meet the minimum power to weight ratio for it to be considered as a "performace car import"
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
