I don't think there is anything other than a 1/4 tank of toulene or the like that will boost your 98RON fuel to 100 or more.
The way mixed fuels get their octane rating is (basically, not precisely) by averaging out the RON rating of each component. If you have 60L of 98RON fuel, you'd need 500ml of something with a RON approaching 300 in order to boost it to 100RON. Does such a substance even exist? Toulene already has quite a high octane rating, and yet you need a 1/4 of a tank of it to make any significant gains.
Whenever fuel companies talk about their product boosting fuel by a number of octane "points", they are referring to the number after the decimal point, not before. So something boosting your fuel by 7 points is less than +1 RON.
Originally posted by red900ss
Now someone please correct me if I'm wrong:
The knock sensor is also called a lambda sensor and measures the unburnt oxygen via the oxygen sensor, right? If the system is a closed loop system then it can adjust the timing to suit the fuel used.
The RB25DET (stock ECU) does not have this as you have to tune it for the fuel being used , right?
Any corrections appreciated. :)
A knock sensor is not the same as lambda sensor... A lambda sensor usually refers to a wideband O2 sensor...
O2 sensors measure the amount of unburnt oxygen in the exhuast.
Knock sensors "hear" detonation and are usually screwed to the engine block...
The RB25DET has two knock sensors on the inlet side of the block... And it will retard the timing and up the fuel if it senses detonation...
I think :P
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
