So after blowing the gearbox I thought f**k this, and ripped it out. 25det to go in!
I did some stuff tonight as it hasn't been so hot, removed the p/s rack, bushes were shagged!
Cleaned the engine bay and removed about what I think is close to 1kg of dirt / grime / sand / rubber / crap from the cross-member.
Stuff going in -
Reconditioned rack (basically new) with lock spacers fitted
nolathane rack bushes
solid steering coupling from gktech.
This combined with the rose jointed rack ends, should feel like new.
Prep wash ftw.
New steering in, reco'd rack, nolathane rack bushes, solid steering spacer, that mixed in with my rose jointed tie rod end junk should be sick!
Pic of front end, after recovery!
That's all folks for now, rb25det is being picked up this weekend!
  • 6 months later...
Been a while, not sure who will read this but thought I'd update with some pics of progress n that.
So I got a s1 rb25, overhauled all seals so rear main, crank, cam seals. Did water pump and put on gates timing belt + new tensioner / idler, painted covers, replaced all heater hoses all that kind of junk. Anyway I'll let the pics do the talking.
had a forward facing plenum made, velocity stakes on each runner.
Pretty in pink
Got myself an oil cooler and hooked that up.
hooked up
RB25 In!
New Rad
The cockpit - made a accessories panel too to plug stuff into.
Pic with no eyelids n that, looks far better
Before its work commenced at garage 7
Steering stuff
cooler mounted, 80mm end takes welded on, lobster tail aluminum
got short piping? :D
Lock modifications!
Surge tank setup!
Had it tuned and the car made 209.8rwkw on around 13.5psi bleeding off to around 13 - 12.8 due to rb25 actuator, short runners let it down a bit in the mid range but i have the solution.. further on in this thread.
So I took her out to round 2 of g1, some piccies.
Now the fun begins..
onto bigger and better things power wise.
Coming -
38mm tial wastegate
highflowed stock injectors (out to 600cc)
z32 afm
steam pipe tuned length 6-1 merge collector high mount manifold
braided lines
modify piping to suit
And already purchased
Genuine Garrett GT3076R .60 a/r anti surge front cover, .83 external gate rear housing.
And -
Shes Naked!
And for the lulz, 25 vs gt3076R
More to come soon
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
