I've got a set of purple top RX7 injectors and I'm having some problems fitting them in. I've got a modified RB20 fuel rail which they fit into quite nicely, but not with the O-rings. I tried pushing them in with the O-rings lubricated with a bit of WD but they won't go in very easily at all. I don't want to push them in too hard in case something breaks.
The O-rings are looking a little tired anyway, I was thinking of buying a new set. Can someone tell me where I can get some from and what I am asking for exactly?
Also, the plastic wiring loom clip doesn't fit. It looks similar though, is it possible to modify the clip slightly to make it fit? If not, where can I get some clips that will fit?
Thanks in advance for any advice.
https://www.sau.com.au/forums/topic/23463-installing-rx7-injectors-in-r33/
Mine were side feed sards:)
Killer T has these injectors fitted, not sure if he fitted them himself? Might be worth a pm if he is still about.
New o-rings should only cost a couple of dollars each, and you should be able to source them from any fuel injection shop, or rotary shop. Would be a good idea to do this as matter of course, as if one goes on you life could get pretty messy, especially whilst boosting:p
I would hope they are pretty tight or they wont seal. I used engine oil to lube my sards up, and they were a pretty tight fit. Perhaps you need a slightly bigger holes in the fuel rail? Any engineering company should be able to help you out there, or a decent performance shop - hills would definately be able to help.
Well, the injectors themselves without the O-rings on fit almost perfectly. They just go straight in and are quite a snug fit without needing any force to push in. I think I just think the O rings need to be either newer/softer or just a tiny bit smaller. I'll take the lot in to an injection shop and see if they can help me with the plugs as well.
Anyone got any shop recommendations for a shop? Worst case I'll just take it to Hills when I'm ready to get it fitted, but for this simple stuff I'd rather do as much as I can at home. I'm pretty sure I can fit the whole thing myself as long as I get the O rings and wiring sorted. Should save an hour or 2 on labour at the workshop :D
I've got a front-facing plenum. This is the only reason why I bothered with the top-feed injectors really, I've heard it's a major pain in the arse to fit top-feeds under the stock plenum.
I didn't modify it, I bought it pre-modified :cool: I'll take some pics this weekend. I will also draw up some plans for anyone wanting to do the same mods to an RB20 fuel rail. You'll need to cut the metal fuel return line off plus the mounting brackets, and put on 2 new ones of a different length.
From looking at it, I wouldn't want to work it all out myself before modifying. With a plan done up, it looks like it'll take a few hours with some sheet metal and an oxy welder. Less if you're good at welding.
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
