Selling complete RB25DE, Gearbox and wiring harness/loom from a R33. All in working order. If your quick enough its still in the car till the end of the week so you can check it out. Package for $1250.
Can also separate if need be:
  1. Engine RB25DE: $600. (121,000)
  2. Gearbox RB25DE/RB20DET: $600 (121,000)
  3. Wiring harness/loom RB25DE/RB20DET: $150
I have alot more parts for a R33, so if you need something i may have it, so just ask. :/
I will take a pic of the engine bay of the next couple of days.
engine back for sale, buyer couldn't come up with the remaining amount.
So can I get a refund of my deposit?
I had every intention of buying (hence the $100 deposit) but due to unforseen & unfortunate circumstances that you are aware of I am unable to proceed atm. Mate keep $50 and refund me half if you think I have stuffed you around. Otherwise hold it for however long untill things change & I will pay you...
Edited by inmate
Bump, engine still for sale.
hey
I would like to buy the engine and wriring harness, but i'm not sure if i would need it as i have a r32 with a rb20de and i i'm going to put the rb25de head on an rb30 block and turbo it. What sort of Power Fc work work on my car?
regards Jordan
As far as im aware the harness is the same for the RB20DET & RB25DE, i dont see why yours would defer, but you should get another opinion on that. As for pfc i would recommend finding out from someone who really knows them. There is a couple of very helpful threads on this topic on this forum, just use the search window. Let me know if your still interested.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
