Was browsing trademe the other day and saw a set of R32 adjustable traction arms for sale. Ive been searching a bit but cant find a discription on what they link from and to and how they work when you adjust them?
Any info would be cool as im aiming for a big hp streeter and dont want to spend all my time trying to find grip!
https://www.sau.com.au/forums/topic/235104-traction-arms/
To correct the rear camber on the rear of an R32/33/34 you need to adjust both the upper control arm and the traction arm. If you don't adjust them in tandem you end up with excessive bump steer (ie; the toe changes as the wheels go up and down). This uncontrolled toe changing disrupts the tyre's contact patch with the road and results in less grip and nervous handling.
BTW, the name "traction arm" doesn't mean that they directly affect the tyre's traction. As described above, their effect on the tyres grip level is secondary and in very much in tandem with the upper control arm. The word "traction" actually refers to their effect in controlling the fore and aft movement of the upright (hub).
One of the (many) reasons why I dislike the use of adjustable arms is the almost total lack of understanding by DIY'ers and many wheel aligners of the side effects of adjusting the length of a control arm to correct camber. You would be very lucky to find an alignment shop that even has a bump steer gauge, let alone someone who knows how to use one. Adjusting the traction rod length to correct the bump steer is a painstaking process, one that the requires both the equipment and the skill/knowledge/experience to use it.
The standard Nissan upper control arm and traction arm combination is pretty much the best matched length for minimising bump steer. Which is one of the (many) reasons why I prefer to use adjustable bushes to correct camber. If you adjust the eccentric to the same degree on the upper control arm and the traction arm then you will end up with no more bump steer than the car has standard.
Cheers
Gary
https://www.sau.com.au/forums/topic/235104-traction-arms/#findComment-4125606
Does lowering the car change any of that Gary or do static changes to toe put you back to where you were before you lowered?
As usual, it depends on how much you lower it, the recommended 340 mm at the rear is OK for bump steer with the standard arms, provided you do the camber adjustment on both arms (upper control arm and traction arm) in tandem. If you go much lower than 340 mm then you need to play with the length of both arms to achieve the desired camber without creating excessive bump steer. For example an R32 at 325 mm has more than 6 mm of toe change (bump steer) over the 75 mm of required suspension travel.
Static toe is corrected by the adjusting the length of the steering arms, that does nothing to correct the bump steer.
Cheers
Gary
https://www.sau.com.au/forums/topic/235104-traction-arms/#findComment-4125716
The only way to really adjust it correctley (as 99% of wheelaligners have no idea) is to do it yourself on a decent machine with the coil-overs removed, sit the car at its normal ride height (on jacks, with chocks under wheels to achieve correct ride height) and move the wheel through its bump and droop arc, watch the toe and adjust the arms to the postion which gives you the closest to std ride height readings.
Tedious to adjust but well worth it (f your need it in the first place), i hate bushes and would rather a little more harshness through some decent QA1 rose joints or similar. But i do agree that many cars i see have 100% wrongly setup arms and alignment.
Edited by URAS
https://www.sau.com.au/forums/topic/235104-traction-arms/#findComment-4125763
so.... If I have lowered tein coilovers on 19" rims, how would i properly eliminate as much camber as possible??
I bought some 'camber' arms for my car, and upon attempting to install them myself, I saw that there was another (upper control arm? sorry I dont know what bit is what) piece that I would need adjusted as well to be able to adjust the camber of my car.
I hope that makes sense, but someone please help. What other part do i need to purchase to allow me to change the camber without effecting the toe (bump steer)? I know i will have to get a professional wheel alignment once everything is on and done
https://www.sau.com.au/forums/topic/235104-traction-arms/#findComment-4146154
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
