Basically undercovers were doing a shift in WA, and a vehicle drives past at an intersection pretty fast.
They think he's doing a runner because his tail lights are off. They go after him and catch up to him at a red light.
He gets pulled over and they tell him to explain....
He tells his story, carrying on etc, fuse blown so no tail lights or dash lights, didn't know how fast he was going. Cops had no radar on him so no conviction.
He had a couple o drinks before but passed breatho.
In the end he gets a notice to fix his vehicle $200 fine and they escort him home.
https://www.sau.com.au/forums/topic/235252-the-force/#findComment-4119663
yeah he pretty much admitted he was speeding, he said "not excessively" lol and cos his dash lights didnt work he couldnt read the speedo. cant believe he got away with it lol. he had a Ova performance workshop sticker on his car is that a well known shop over there?
https://www.sau.com.au/forums/topic/235252-the-force/#findComment-4119774
I was surprised the law didn't have a radar; so was the guy!!. he was releived when the cops said they didn't know what speed he was doing. then the cops looked disappointed when he only blew .037 on the drunk-o-meter. pretty heavy fine for a fuse.
https://www.sau.com.au/forums/topic/235252-the-force/#findComment-4119780
yeah mate some rediculous fines/sentences the courts have.. you can serve longer times for lesser charges than murder!!! how stupid.. and if the cops ever ask.. just dont tell.. cause if they ask thenusually its cause they dont know.. you admit to a crime then they got you
https://www.sau.com.au/forums/topic/235252-the-force/#findComment-4120324
it wasnt a fine for the fuse, it was a yellow sticker/work order to get the whole car checked.
serves him right for driving a unroadworthy car
lol when he was begging the cop not to give him a sticker & he said come around to my house & i will show you ive fixed it.
then when it was over he was saying i was just on my way to buy a fuse lol
Edited by NWR31
https://www.sau.com.au/forums/topic/235252-the-force/#findComment-4120457
yep, I know it was for the inspection but according to the guy, the problem was caused because of a blown fuse.
https://www.sau.com.au/forums/topic/235252-the-force/#findComment-4121305
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
