Turbotech boost controller (the model with the bleed hole) - Brand New, never got a chance to use it as my cars off the road and i just recently puchased a EBC so i now have no need for this - $25
I also have a Stock R33 S1 VLSD for sale its in good condition its done ~100k's - $150 Pickup Only or if your a melbourne buyer ill be going up their next week so i can deliver that if your in the metro area
https://www.sau.com.au/forums/topic/235394-turbotech-bc-and-r33-s1-stock-vlsd/
Boost Controller Still for sale, And i have the following up for sale now too
R33 and R32?? Poly Urethane Front Diff Bushes - Brand New $30
Green Label R33 AFM - Perfect Working Order $70
Dash Surround And Center Console - Dash Surround Needs Repainting and Center console is in good nick just has broken latch - $25 for both
Custom made C Spanner For many time of coilovers - Brand new - $20
R33 Leather gear boot - like new condition - $10
Z32 plug - Good condition comes with 20cm of loom i have 2 now so need for this one - $20
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
