SO many variables. Believe it or not other cars have had a much harsher life than others.
Correct........you take 2 cars with identical mods yet one has a fresh motor while the other is lacking compression with crappy plugs and I guarantee a difference of at least 20 or 30kw.
  • Replies 54
How much effect does the ramp rate have on the over all figure. it would be the same difference as doing the run in a lower gear because that is effectively what you are doing by altering the load. I.e. there wouldn't be 10% difference in a 200kw car due to RR more like 2 or 3.
Also this engine had extremely good compression, i posted the figures up in the wasteland when i did the test because I wasn't sure what the range factory range was, but they were all around 169 mark with very little difference between them
Edited by D_Stirls
Actually sorry steve have to jump in here noone's actually said he didn't make the reading there just questioning the equipment they used to get the reading!
comprehension i never once said he didnt make that figure just what were the dyno settings was what i was implying
remember people its just a number.
yeah but to some it seems figures are more important than where their car is at!
i only pulled 185kw with a pfc (got a restricting exhaust) but some how i still manage to be right next to my mates skylines even though they have more power! as long as i feel the result i'm happy
The more power the car has the more dramatic the power difference is going to be when you vary to ramp rate. Ovrtym33's R33 made 325roundaboutrwkw on moderatly high ramp rate which was around 270 i think. Due to the fact we had to dial out alot of wheel spin on the dyno. On a more modest / realistic ramp rate the car would probably make around 340-350rwkw....however the same ramp rate differences on a 200rwkw R33 would be around 10rwkw difference. not too much but enought to make a customer drive out happier lol.
well the car was actually on the dyno to find an ignition fault which turned out to be the No. 2 coil pack. The figure was just a bonus, i told Zac that he wouldn't make 200 until they played with the SAFC but you never know, that's the thing with playing cars.
He's now giving me shit about how much effort i put into my CA to get 16 kw more :) . But I'm only a decent actuator away from 235.
Edited by D_Stirls
Yep, but that's what you get when you try and 18 psi through a 9 psi actuator.
I only put 2mm of preload on it though so I might try a little bit more and see if that works but i suspect it'll just make it spike higher and then drop to the same point. I'll by a 13.8psi actuator and bring that along when it goes on the dyno next.
Edited by D_Stirls
hey im in the same boat, took my car to turbo tune bout 6months back, i hav a fmic, hks cat back, walbro 500hp pump, pod filter and running 11psi flat (earthed out solenoid). My car got a read out of 221.1rwkw. My engine is a bit weird tho you cant run the pod straight off the airflow meter cause my car will just flood up wen hitting boost. i need an extra bit of pipe on the end and then it runs sweet, turbo tune said they hav never encountered a problem like that
dynos are only good for tuning. and bragging rights :P my car made 235rwkw on tilbrooks dyno with standard ecu and turbo running 13 psi.
thats way too high..... since then the car has had a haltech e11v2 installed at boostworx and runs the same boost but made 197 rwkw on boostworx dyno :P .... that being said the car is heaps more responsive and pulls heaps harder.....
Your right that is way to high but that's Tilbrooks dyno for you.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
