Hi guys,
I'm in need of some help. I have a small job for an auto trimmer. I have 2 race seats and I want small suede patches attached to the high wear areas (just like many newer race seats like my cobra evolution now come with standard). On the surface it doesn't seem hard, but I imagine it will actually be a little tricky as the race seat cover fabric is usually quite weak meaning it's not easy to stitch stuff to it, usually means some kind of stick on patch, or put stronger fabric underneath and stitch through the lot. These are very nice seats. Carbon Kevlar recaro's so the job must be done nicely.
Anyway, please reccomend anywhere you know of, or even better somewhere you've had work done. I live in inner city sydeny so somewhere close to their would be ideal. :P thanks.
Rich, a mate at works old man, has had his vintage Merc done by a group here in Syd, but can't remember the name right now. I'll find out tomorrow. He was very very happy with the work.
Not on the cheap side, but in his restoration went to the trouble of specifically sourcing the exact leather texture of the original seats for the restoration, from Germany.
barry hopkins motor trimming in artarmon... hotham pde
when i worked for honda we use to send brand new type r integra seats there to get built as they came from the factory in like 20 peices and they built them!
roger that. I will see how they turn out.
the east bear seat in my silvia is fked and I don't want this to happen to the recaros in the 7 (new covers for them are $900 for some reason, even though normal recaro covers are about $200). my cobra has nice little patches or leather or something in the high wear areas and that's what I want for the 7.
if you have a regular, recaro/velo/cobra or whatever it's probably worth buying a new genuine cover. the only reason I can't for the 7 is that those seats were specially made for mazda so recaro wont retail covers for them, you have to buy from mazda. but normal recaro fixed seat covers are quite affordable.
Here you go Rich,
this is the group my mates dad uses. Was talking to him today and they absolutely rapped with the work. He said they can at times take a bit longer, but never had an issue with quality.
http://www.prostitch.com.au/
Carlton is about 2 mins from my place
Ive been in there before, rates seemed very reasonable and the level of work is awesome (they had the shop full of customer cars when i was there)
Once i get my 32 back im going to get the seats retrimmed by those guys
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
