Please no time wasters please only contact me for a cash sale with the funds available now not in a few weeks etc. Price drop get me a sale with anyone?
Hi mate, great looking car at an insane price, one thing though would you be able to post up a pic of the Blue Nissan Build Plate? Also, would just explain why you've decided to sell the car? Thanks mate just wanted to register some interest in this car =)
Cheers
Danny
Edited by squareznboxez
Ohhh how i wish i had the money to buy it now :merli: hope a deal like this comes up again in 2 months time lol
gl with sale man im stunned at how this hasnt been sold yet
I think its pretty much sold now i hope after tomorrow ill know. ill take a pic of the build plate for you dude and post it up. im selling for a few reasons. want a manual and a change im thinking s13 or a integra on the jap side...maybe audi 1.8t on the euro side.
Wow that price is ridiculous!
I've got an n/a R34 and this is at least a good $4k cheaper than what it would cost to import.
If this was for sale in Melb it would have been snapped up the minute it was at $13,000.
Either way good luck with the sale!
R34's seem to be going through an incredibly hard time selling atm, they're beautiful cars, it sometimes makes me think about buying one for the moment.. Great car Brooks, hot 19's, as soon as i get approved finance you'll be hearing from me chap
Danny
