I think my fuel pump is on the way out, cause the car keeps missing and leaning out. Are R33 GT-R pumps a direct swap for a R32 GT-R? cause i have access to one. And what is involved in putting a Bosch 023 in?
car is making 311rwkw on the std fuel system. I don't want more power, just don't want the fuel to flowing.
https://www.sau.com.au/forums/topic/235704-r32-gt-r-fuel-pump/
Using a 2nd hand pump or a new one?
Risk is using an old one, you'll have the same problem again in "X" amount of time.
You could always go Nismo or Tomei, they are drop in items so R33/R32 should be interchangeable
I don't think a bosch is being too cheap, i just don't want to pay for the convenience/name of nismo and tomei.
the 044 is longer than the std cradle isn't it? how much do you have to do to fit it in? and as far as wiring, you only have to run the earth to the body don't you?
I just watched as mine was put in so i cant remember 100%
Although, here are some links that will help :D
http://www.skylinesaustralia.com/forums/in...t&p=3658205
http://www.skylinesaustralia.com/forums/in...t&p=2053785
that don't look too hard at all.
Now is there any trick to get that cradle out? cause i dropped the tank out and cleaned it last week, but i couldn't get the cradle out (didn't want to break it)
It slides into place than locks
I think it was right to left? It has grooves that match up to other grooves on the bottom of the tank and slides into place the same way a tray slides into a fridge
That may not make a lot of sense...
