WTF why you going interstae Michelle. You racing in F1 or doing the QTR ? You see the Silver GTR 4Sale at DAFF ($20k) looks straight and has less than 70,000 klms genuwine!
I'm racing the open wheeler in the hillclimb on the Sunday and hope to make the show n shine on Saturday (time permitting). As much as I would like to run the GTR, she's being treated like the Princess she is :( and although I was tempted to buy Anthony's GTR, I simply don't have the room for more cars here.
ps where the hell is Bulahdelah ;)
Its about 90k North of Newcastle and the hillclimb is on an old section of the Pacific Hwy which they will close for the day http://www.hillclimbnsw.com/bula.html
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
