  • Replies 260
problem with sa car scene is its too full of big headed wankers, which makes things like SCS fail, because everyone takes the attitude of 'rice this, autosalon that'. if you dont have the right offset then how can you be in a car show?
SCS is(was) a good thing for Adelaide, admit it, any car show in Adelaide is a good thing and can only help the scene, the people in the scene is what lets it down.
+1
Thats so true. Everyones bagging out each other's car whinging about this that etc... people were complaining about the car scene dieing in Adelaide earlier this year and when something like this comes up everyone whinges about this and that AGAIN! Its not the organizer's fault that the car show is dieing more and more every year - its because everyone goes around bagging out the show and the cars; in turn making people less incline to want to go or want to enter! Its up to the car enthusiast community to provide the cars for the show AND attend aswell as spreading the words about it... NOT have the attitude of "oh my cars too good for SCS I'm not putting my car in that rah rah rah" + "oh I'm not going to SCS its crap compared with rah rah rah" + "Everyone dont waste your time at SCS its rubbish rah rah rah"...
I'm not pointing this specifically at anyone but more in general theres just too much bad mouthing this and that... wheres the love!?
i agree its most peoples attitide that wreck a good car show atmosphere,
but hey, its the way it going to be.....
thats the world today.
i never got to experience the car culture before it turned sour, hell, i have NEVER had the opportunity
to run any of my cars down the drag strip...
is this the way our kids are going to enjoy there cars?
this seems like the new school mentallity
^^ agree with the comments posted above.
20 bucks for a day out at glenelg, then if you get bored you can go for a drink or swim, and not get sunburnt or couped up in a tent like previous years, plus you get to hang out with your club buddies and check out the other clubs... i don't see any downsides to this event. It should be as good as AJD, if not better.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
