again whats blowby, i thought it wasnt too bad to blow a bit of black smoke out the exhaust, thought it was just cause of the big bore piping that these cars have
whenever i'm at the workshop watching a car on the dyno waiting outside for mine to go on theres always a lot of smoke coming out under full load.
thanks
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-507326
Blow by is the gases going past the pistons during combustion, these gasses are circulated to the rockercover where they then get redirected, one way or another, to eventually be burnt again in the cylinders (if you dont fit a atmo vent catch can of filter).
If the rings are starting to wear a bit, blow by will increase, and it would be noticable when opening the oil filler that alot of air seems to be getting forced out. If there appears to be no air being forced out, 'usually' means the rings are ok.
Jimbo2000, the smoke you see from a dyno run is because the AF ratios are intentionally richer during power runs, which helps control detonation.
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-508227
how do u know that the compression was 125?
are u sure that the gauge is correct ? if they are all 125 the gauge mynot be right or the engine not normal temp .to check if its bottom end prob ( warn rings or pistons ) do a compression test note the comp on all cil then squirt a small amount of oil in the cil crank a few times then check comp again if it raises say by 10 psi or more u have bottom end prob ( warn rings more than likely )if it doest rise it means warn top end ( valves or valve seats ). the other way is to do a cil leakage test , this is how u do it : spark plug out install i tube with a threaded bit at the end that screws in to the spark plug hole car in gear handbrake on then put compressed air in to cil (150 psi ) and listen far air leaking ( bottom end or top end ) .
note most of the time if engine runs good makes good power doest use a lot of oil and u find low compression ( but all cil the same ) its your gauge or the method u are using not correct so dont panic if all the above are right .
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-508747
what they did when they did my test (wasnt paying too close attention so didnt get a good look at what the instrument actually was) they had the plugs out and inserted the probe thing with guage on top into each spark hole (real technical! :) ) and turn the key for about 2 seconds.
wasnt 125 exactly on each one but pretty close.
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-509235
standard compression for rb25det is 1.2mpa (12.2kg/cm2)or 171 psi ( apr) limit .9 mpa , 9.2 kg/cm2 or 129 psi . thats at 300 rpm lower rpm = lower comp.variance is 14 psi . rb26 is slightly lower .like 2% lower as it has a lower comp and runs much higher boost . jimbo if urs has a true 125psi u wouldnt have much power unless u run very high boost but i dont think it would be that low .
it would be hard to start if it was that low too ( like taking a few cranks to start it .
https://www.sau.com.au/forums/topic/23699-low-compression/#findComment-509583
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
