  • Replies 310
Posted Images
yeah i want to print mine up first to see how it turns out than ill take a photo of it to show you guys and if you like it than we get a bulk print out. makes it more easier that way so people can see what they are getting from the end result.
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4206867
i got quoted 85 bucks with a fleecy hoodie. but thats for 1, imo thats a pretty decent price for a nice looking hoodie. thats why im waitin on my blank hoodie itll be alot cheaper to print.
Edited by gtrkiet
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4206949
ok so this is the design.. itll cost $60 to print this design on our existing hoodies. and theres a one of fee of $150 for setup colour charges... what do you guys think? itll cost an extra $30 if we want to print something on the front aswel which i was going to have SAU on the front left chest but it would cost too much because theres a $130 one of fee for that aswel. This is all screen printed on aswel not stiched or ironed on.
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4213779
do you want to pay extra ?? lol... imo this would cost too much.. and even more if you would want a sau logo on the front AND your name lol... and + names would be too much head f** if you want your name than just bring it to ur local embroider to get it done.
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4213805
Woah geez thats a fair descent amount JUST TO PRINT! Get quotes from other places... The Prelude Australia hoodies was only like $50 delivered to my door - that included the hoodies itself, printing on the rear AND front.
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4213806
i think the rims need to change, like just a basic 5 spoke design, its the only thing i dont like with it
i originally had the spokes on there but it would be too hard and the lines wont come out good and itll look way too detailed.. i tried to keep it as simple as possible.
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4213807
how did the quality turn out? was it screen printed? could you be a spy for us sau'ers and ask them where they got it done? lol
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4213811
thats what i was getting to kiet
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4213820
*cough* BS Keits screen printing is VERY cheap even there setup costs are very dear
the place i was looking @ has a setup cost of $45 for each different colour and printing of up to A4 was around the $4.50 mark
good work on your design though would you like to see how much it would cost with the guy i was going to use
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4213844
OK design Kietz but you're dreaming if you think people are going to pay $60 for print only
https://www.sau.com.au/forums/topic/237131-hoodies/page/7/#findComment-4213850
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
