Today I had a Bosch 040 supplied + fitted for $340.
Previously with the std pump 7psi (190rwkw) drove absolutely perfectly but 12psi (203rwkw whilst leaning out) was coughing and spluttering.
Now 12psi is as good as 7psi after the new 040 pump has been fitted.
Very happy because the 040 will leave me with plenty of headroom for future mods.
Originally posted by benm
Theirs no way i'll be turning it up to 15psi, 12psi is enough for me right now (I need to burn that in as it is).
Having a standard ECU means lot of things can go wrong. :D
Such as? The stock ecu throws more fuel in and less advanced timing, if anything its going to protect the engine. Granted it has a boost/fuel cut which spoils fun, but it certainly isnt going to harm the engine in any way.
would the standard pump running into a surge tank with larger fuel pump be enough? or would you need 2 pumps of same flow rate for this to work best??
anyone put a surge tank in the boot of a skyline, or are the fuel tanks baffled enough not to worry about starvation on the track??
craved, I don't know about the inner design of the tank, but I've never had a fuel starvation problem on the track (but then neither do I take it out with under 1/4 tank)
yeah neither have i, well not that i've noticed anyway, just looking for an easier way than replcing the one intank, plus the looks etc of an anodised surge tank in the boot :P
do you know if it would work or would the high pressure pump empty it too quick to be feasable?
Craved I got my Bosch 040 (520hp) intank fuel pump supplied + fitted for $340.
To get an external pump/surge tank etc supplied + fitted by UAS was going to cost basically $1,000.
Unless you drive around with your boot open I reckon the ~$600 could be spent elsewhere, like some slotted front rotors.
damn, a grand!!!
they sell the surge tanks for about $250, plus the fuel pump, the rest can be done yourself!!!
but overall just looking at whether its going to work the way i was thinking, main reason is that i have to do this setup in a sprinter as well, since the engine conversion it has major surge issues running from the VL turbo pump!! The old AE86 dont have fuel tank baffles, causing major issue at the track when less than half a tank!!
Hi guys, by plumbing it into a surge tank you take the load (resistance) off the standard GTST pump. As an example we have a GTR that uses a GTST pump in the tank pumping into a 1.5 litre surge tank with 2 X GTR pumps feeding the engine. The surge tank is never empty, the single GTST pump easily keeps up with the requirements of the 2 X GTR pumps supplying the 6 X 1,000 cc injectors.
Hope that helps
that was exactly the answer i was looking for sydneykid!!!
thanks heaps for that!!!
just one more little question: do you just Y piece the return line and the surgetank overflow before the fuel tank, or do you need a separate lines to the tank from the surgetank and return line ??
Cheers
Hi Craved, I do it a little differently than some I have seen. I return the unused fuel from the engine into the fuel tank, not into the surge tank. I have found it comes back from the engine warmer than when it went there. The compression effect of the fuel pumps, the heat transferred from the fuel pumps and the heat in the engine bay all get together to make it hotter. So if you keep going around and back into the surge tank you end up with really hot fuel which is not a good thing.
So I use a Y piece at the fuel tank for the surge tank over flow and return from the fuel rail.
Hope that helps
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
