hey guys.. Looking at upgreading my brake pads and disks on my S2 R33...
I was thinking going Slotted break disks and maybe Green stuff pads...
any oppinions and suggestions would be good..
I'm not too sure were the best palce i can source good/cheap break disks or pads form so any help would be good...
thanks guys =]
Edited by Royalflush
just put a set of DBA street series slotted rotors on the rear of my r33 with a set of ferodo XL pads... awesome braking now they are run in...
I won't get into a DBA vs. RDA argument, cause they never end well, but the one thing people are starting to agree on quickly is QFM pads...
If you just do street stuff, then the QFM HPX pad is the same sort of performance as something like a Bendix Ultimate, but if you ever plan to do track work, or want the best street brakes available, the QFM A1RM is still a 100% streetable pad, and is good for 780 degrees, and what we personally run in the rally car. Group buy pricing of half price rears is sort of just sticking around, so you can get front and rears A1RMs delivered to your door for $191, or $131 for the HPX.
http://www.skylinesaustralia.com/forums/Au...ra-t231267.html
Some of the recent reviews of QFM:
http://www.skylinesaustralia.com/forums/Br...t&p=4138203 (SAU)
http://www.skylinesaustralia.com/forums/Br...t&p=4141983 (SAU)
http://forums.justcommodores.com.au/820679-post3.html
http://www.boostcruising.com/forums/index....mp;p=1282156408
http://www.boostcruising.com/forums/index....mp;p=1282506286
For more information checkout www.qfmperformance.com
I need prices.. 4x new disks & 4x new pads.. where to buy and whats best for street?
Check in the Group buy section of the forum for RDA prices, as they're very good, and I won't take it away from them. But with regards to the pads, if its street only, then QFM HPX pads are as good as Bendix Ultimate's in performance, but minus the dust and rotor wear. I'm still honoring the group buy pricing of half price rears, which makes a front and rear set delivered to your door for $131.
Cheers,
Greg
Definitely check out the Group Buy section, there are good prices on slotted rotors and EBC or QFM pads, cheaper than buying through a normal auto parts store (unless you know someone there who can get them at discount or staff price).
Honestly, having running std rotors, old school DBA rotors, new/current design DBA rotors and RDA rotors....if there is nothing wrong with your std rotors then keep them.
If they are undersized then sure replace them...but if they are ok thickness wise then keep them. Speak to your local brake shop to see if they can do $100 worht of machining some slots in them. It may be viable. The more i see of DBA and RDA rotors they are a cheap replacement rotor, not really great replacement rotors. The DBA 4000 series arent too bad for sporting driving but thats about the limit of them. RDA, well you get what you pay for and if you start to throw lots of heat through them i dont think they do as good a job as std or DBA rotors. Just an opinion....not a fact :P
Just ensure you run a good performance pad and good brake fluid. Pad feel is veyr much a case of driver preference so you may have to try a few until you find some you like.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
