Yer its gay as :P
If it makes you feel better today i opened my roller door half way thinking my car was gonna clear it but i forgot about the antenna bent the hell out of it.
At least you know it wont happen again though coz you will be more cautious, well that was the case with me
  • Replies 50
Yeah we had a lil time so we went looking for ya's lol
the rim isnt too Bad, its the worst feeling hitting your rims.. I just didnt know what to say coz i know the feeling and nothing n e 1 can say can make u feel better :) But they can be fixed :D
ross i think i saw u in watergardens about 6... i didnt know if it was u or not so if it was u and i snobed you i'm sorry LOL
Awell next time i guess..
I think i was in watergardens at that time but cont remember seeing ya :S
Ohh cool then i wasnt a snob HAHA!! ohh hang on am i coz i saw u and didnt say hi... lets just pretend i wasnt there lol :)
hmmm....i might be down...will be down for a little bit though...as i'm cramming in some last minute homework before skool tomorow LoL.
if more people come i'll come down for an hour or so.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
