hi i own an r32 and am about to purchase some wide front and rear guards for it
now ive heard dmax is of the best quality, anyone bought dmax or know of the quality??
i should hope so that they good quality for $400 a pair front and rear
now the dmax branded wide guards only come in i think 15mm or 20mm rear fenders and 15mm front (although there is the d1 spec 30mm front guards but they stick out outside the door)
so i dont know if should go with the dmax fenders?? or go for cheaper more wider fenders from somewhere else?
anyone know where i can get some wider ones that are of good qaulity?
sorry for all the questions
thanks guys
https://www.sau.com.au/forums/topic/238496-front-and-rear-wide-guards/
yeahh i bought the dmax front fenders and just fitted it like 3 weeks ago
all i can say is that i encounter a few problems ..
first of all the fenders are too thin which can easily be crack if someone lean on it
so i had it re-fibreglass which cost me $100 each ... (rip off i reckon)
and secondly the tip of the fenders where it line up with the front corner indicator
has a gap that run all the way down ..hard to explain need to show you guys pics
and lastly it dosent line up with the bonnet properly, it sit abit higher ..
thats about it ..maybe it was just a one off thing for me or the guys
that installed it did a shit job .. wasnt happy they offered to fix it but
i have to leave the car there for a few days .. havent had time .. soo blahhhhhh
other then the above problems it fits good and look good aswell
  • 4 weeks later...
dude imho spend the money and get decent guards i payed 500 a pair front and another 500 for the rear they were espensive but the quality was awesome.if you go cheap guards almost always the quality will be shyte, they were veilside combat r by the way on a r33
dave, the part where it sits higher then the bonnet, that can be fixed with just some sanding to make it even :down:
if you got problem with them, speak to the dmax seller/rep and he will look after you.
URAS gaurantee 100% fitment on them, but it also depends on the car whether its had previous accidents etc.
heres a picture of mine. for some reason the front guards are strange.. the bottom of the guard where the side skirt meets it is narrower than the factory one and leaves quite a big gap
behind the wheel. dont know if they were made that way intentionally??
thats one fkd up widebody job it looks hell dodgey + those wheels dont fit what so ever ahahha fail
geez a bit harsh considering i spend 2 hours a week working on it for 4 months not to mention im not an exprienced panel beater :)
lineedup33 i got them imported from japan
do you have any more pictures of this?
think it looks wierd cause of the rims, rims look abit to small and needs some (alot of) dish
but good work for a non exprienced panel beater :blink:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
