Item: RB30DET motor
Age: 6000km
Condition: Perfect
Price: $3000 ono
To Fit: (What car) Any RB series
Contact: not304(AT)optusnet.com.au
Consists of:
* RB30 block, bored, decked & chemically cleaned...
* Linished crank & modified crank collar...
* Aries forged pistons, pins & spiral locks...
* ARP rod bolts...
* ARP head stud kit...
* ACL race series bearings...
* NEW waterpump...
* RB25DET oil pump...
* Bradided turbo oil lines with Speedflow fittings...
* RB25DET head, modified oil gallery, head surface ground...
* Cometic multi layer headgasket...
* NEW valve stem seals...
* Adjustable cam gears (NEW not yet fitted)...
* Braided oil drain + Speedflow fittings from head back to sump...
In perfect running condition that has only done approx 6000km.
Recently compession tested for this sale & has 160psi in each cylinder.
Complete less manifolds, wiring loom etc.
Selling due to hassles of converting the Stag (upgrading trans, diffs, brakes, 4WD adaptor etc). An easy 400+ KW engine depending on bolt on mods.
Edited by inmate
https://www.sau.com.au/forums/topic/238627-fs-fresh-forged-rb30det-engine/
hi got a few question what CR was the motor set upto you say its being sold due to hassels with fitting drive line up etc with the stag but yet it has 6000kms on the motor can i get some more info or history with the motor also what rods are used standard rods or forged
cheers kyle
With the cometic gasket it has 8:5.1cr.
Running standard rods with ARP rod bolts.
It was used in a RWD car for running in.
It only ever seen 7psi due to having a standard ECU tune.
I am converting my car to straight LPG so it would be a waste of money for me to purchase an aftermarket ECU, bigger injectors etc. For this reason it has not been dynoed, nor has it been boosted or driven hard etc. Has more than likely done less than 6000km but I am using that as a indication point to give interested parties a rough idea. I would rather over quote its milage useage than underquote it if you know what I mean...
Edited by inmate
$2500 if picked up within the week...
Alot of tyre kickers wanting to discuss there big plans & see pics,
but no1 with the actual money to purchase. Will leave this advertised for 1 more week untill 13/10/2008 and if it hasn't sold I will keep it & continue with my original plans...
Edited by inmate
  • 2 months later...
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
