Hey guys, need some help.
Got defected by the cops for my Pod Filter.
Need to cover it with the Just Jap box, but in order to do that i need to extend the Pod to the bottom right corner of my engine bay, towards the Water Bottle.
I need some opinions on how to do so, and have attatched some pics of the engine bay and the actual box i want to get.
Thanks in advanced guys!
MRXTCZ
https://www.sau.com.au/forums/topic/238650-how-to-extend-pod/
Just Jap box is a good option,
however you can build a box with about 40 bucks and 3-4 hours.
Search in the DIY forum. I think someone in the central coast did it...Jim, if i remember correctly, i forget his forum nickname.
Anyway, with summer just arriving, put back the stock airbox with a high flow panel filter. Pods = unresponsiveness in warmer conditions.
UAS sells a fibreglass airbox for pod filters, specifcally for 34s for $190ish.
I so wouldve, but i dont have the stock air box man. It sucks big time seriously.
But yeah, i need to get this up and running asap.
I would make it myself, ive seen the DIY but i just dont have the time at the moment to make it myself. And the Just Jap one looks heaps neat :P
MRXTCZ
Maybe use a metal elbow pipe.
http://www.skylinesaustralia.com/forums/In...te-t232764.html
That seems to be fairly close to where you need it to be, if you can get an elbow the right length then it should be sweet.
Something like this (provided it's the same diameter) might help you extend, and it still retains flexibility to get it exactly where you need. Might need a bit of modding to get it right.
http://cgi.ebay.com.au/HOLDEN-COMMODORE-VT...1QQcmdZViewItem
If you used a black elbow like that, combined with a black pod enclosure, it should look fairly standard and won't stand out too much next time a cop takes a look.
Edited by N-DAWG
Cheers for that but i cant see any of those pics, and the second link doesnt work for me.
Walked into Autobarn last night, they had these plastic and metal pipes and elbow's aswell.
But the thing is, i just need to know what do i do with the additional pipes that come off the stock intake pipe? because if i extend it, when will i do it from?
MRXTCZ
MRXTCZ
Direct image links:
http://i73.photobucket.com/albums/i229/l337z1ll4/845f_1.jpg
http://i7.ebayimg.com/07/i/000/be/de/45dd_1.JPG
Just remove that square box that connects to the intake, and replace that with the elbow. Keep the piping with the AFM and all.
The first image is in the interesting pod filter setup thread.
Metal screams out modified intake. black piping going into a box looks more standard.
If you're getting pulled up a lot by cops I'd go the latter. It sucks having to do things like this to prevent unwanted attention but sometimes it's better than the inconvenience of defects etc... :P
Hey Howie, yeah man. I copped 2 defects in the past 2 weeks for the poddy, so i need to tend to it ASAP!
dori32, ive been lookin' for ages, but i might aswell get the full CAI going with the poddy and all.
Oh well.
Heading over to Autobarn and bunnings this arvo after work, see how it goes ;)
MRXTCZ
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
