Condition: A1
Price: $2200 + delivery
To Fit: skyline
Contact: PM or call 0431 520 274
Don't want to sell these but need money to fund the track rat.. so looks need to be compromised for function...
Have had these wheels for about 4 months now..
Work meisters 18'' +18 offset..
It's got a bit of dish on them but not as much as other examples. Unfortunately only 8' wide.
The wheels themselves are in fantastic condition with no gutter rash, few scratches when removing nuts, nothing that you can actually see unless you come up real close.
Tires.. they are mismatched but road worthy (let's say 65-80% tread) 235's all round
PM me or call me on 0431520274
https://www.sau.com.au/forums/topic/238778-work-meisters-sp1-wheels/
These look kick ass on 32 GTR's! Can't believe Im not getting the interest they deserve!
0431520274
Call me if interested :cheers:
Edited by Tomek
BUMP
Can't believe im having so much trouble selling them..
There big, there shiny, look kick ass... Have ABSOLUTELY NO gutter rash, there in real good nick.. But no one wants them..
PM me if your interested!
Edited by Tomek
They are 8's, that is why
Yeah thanks for the bump :(
Still doesn't change the fact that there a kick ass rim, not everyone does motorsport events or owns a GTR..
They look real tough on GTS-T's.
I too am shocked.
Id love these wheels!
Unless you want swap stock R32 GTR's with brand new high quality rubber and cash your way, its free bump :)
Best of luck!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
