Originally posted by ac1d3o3
serious? the government got off thier ass and did something hahaha
did they change the actual entrance to the driveway or just fixed the bodgey job they did in the first place?
They just fixed the drive, no complete reconstruction. Took about 45 minutes and no one could drive in for 3 hours... If you want to mod your drive yourself you need council approval just as INASNT said...
https://www.sau.com.au/forums/topic/23882-driveways/page/2/#findComment-513991
if i back straight out of one of the bays in my garage i will go down into a garden bed, so when on that side i need to turn as i reverse. one time i was late for uni and quickyl overturned and reversed, as my car backed out, the front bar hit one of the shelves in the garage and cracked the corner of my front bar... fibreglass all over the floor... very gay.
https://www.sau.com.au/forums/topic/23882-driveways/page/2/#findComment-515861
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
