  • Replies 52
Thanks for you concern 2ltrv8
But i only plan to boost it to 0.7 bar... not much at all i know. But i think that way the clutch wont die so fast on me until i can replace it with some more heavier. Then after that i will turn up the boost a bit more.
Im just very confused with the dump/front pipe.. there are so many styles to choose from i really dont know what to pick.
I guess more research for me..~
0.7 bar is enough to lunch the clutch bro, depending on your driving style.
Really man, it's a good investment, the previous two posts support the act.
As far as the dump, mine is the dump/down with divorced wastegate. As stated it produces less cavitation and interferes less with the vortex down the system. They cost a little more but I won't turn back ever, and I've recommended them to my club with the same positive results.
Ultimately the choice is yours my man, just take everything into account before making YOUR descision.
im not saying dont do the clutch im just saying its probably not even slipping yet.. and hes not even making descent power yet
10 psi isn't even that much boost
once you start going past 12 psi theres lots of parts at the end of their life and limits... fuel pump, injectors, afm.. maybe he should change all them before he gets a full 3 inch and ups the boost to 10psi :thumbsup:
I'd say go the clutch first
As Jarrod83 has said the clutch can be eaten quickly once the boost goes up. fortunately for me mine had putted around for some time before both me and him noticed it slipping.
Then one night while i was up north of the river the clutch decided to pretty much die
i got home the following morning moving at about 10kmph and the car didnt even get up the driveway
car stayed there for 1-2 weeks while i waited on a clutch 2 days after i got the clutch luckily it was a weekend both me and jarrod83 threw it on in there with the car at home on jackstands it wasnt the best way for it to go but sometimes u learn the hard way.
in other words i suggest the clutch be replaced before upping the boost or before trying to get any more power out of your car :thumbsup:
goodluck :D
i have a Greddy profec boost contoller
i wouldnt recommend it, its too hard to change boost settings on it
just jap sells a split front/dump that bolts straight up and is about $250 from memory
Profec B specII?
PROFEC B, simple to install and easy to operate. 2 settings high and low and hold boost well.
Agreed.
I vouch for Profec B as well.. I had it on my car last time and whenever it hits boost, it just holds there really well :)
Agreed.
I run a Profec B SpecII and it's mint, some people just can't get their head around how they work :woot:
I also run a 4-puck sprung brass button clutch with a heavy pressure plate, it's also mint :D less pucks = more agressive engagement :D
Maybe even get Kermit to do a custom dump pipe, or jjr split or x-force bellmouth. The results will all be much the same. Quality would be the issue you want something that will last. Any high flowing cat will do the same job, or just go de-cat.
I have heard bad things about the apexi boost controllers. Best bet is to go for a blitz DSBC. I think there around 380 new and hold boost real well.
With these mods tuned with safc your looking around the 235-250 accurate hpatw as long as your fuel pump is ok.
Oh yeah, I'm also running an XSPower (I think.. it was written on it but been a while since I last had it off) split dump into a 3" front pipe, no issues. Have heard of lost of issues with the JJR split dump/fronts though.
Hm
Ok.
So say if i did exhaust, then clutch and fuel pump.
THen finally tune with safc 2 and with boost controller (yet to be deicded)
Is it alright for my car to be running FMIC and Full 3 inch exhaust with out being tuned? for im assuming 3 - 4 weeks while i get more money together for the tune?
Edited by br3ndan
Sure is. The FMIC and exhaust won't affect your vehicle without tuning at all.
Yeah absolutely fine.
Alright, looks like ill be heading down that track then.
Poor safc 2 can sit on my table for a bit more longer. haha.
Ive decided on a bellmouth one piece front/dump and a hi flow cat but unsure between cermaic or metal. I know cermaic is cheaper,, and apparently easily gets blocked? So maybe its worth the extra dollars to go the metal cat? Ill probably got Xforce on both. Sounds good?
The problem with ceramic cats is that if your car is running rich (which most of ours do, and some more than others - particularly those with base mods and no tune), the richness causes the ceramic insides to collapse. I wouldn't bother with a ceramic Xforce cat.
These are the ones im thinking about getting... Are they the correct ones?
http://justjap.com/store/product.php?produ...=275&page=1
http://justjap.com/store/product.php?produ...=252&page=5
These will bolt straight up into my hks hi power cat back right?
After i install these, my exhust system will b complete?
I wouldnt worry about the clutch, it will hold fine.
As for the boost controller, you dont need to know how to use it really because the tuner will/should give you the best result with it anyway, just say what PSI you want to run on hi and what psi on lo and you should'nt have to modify it after that. I for one have the profec 2, looks nice and works 100% fine.
I would recommend getting the fuel pump done beforehand. My car ran lean on the dyno because of a dying fuel pump so I had to buy a fuel pump off them and pay them to install it so that costed quite a bit of $.
The tune made a huge difference in power, then it got boring after 3 months :thumbsup:
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
