Hi guys,
Im just wondering if anyone here has got or heard off the following mod's . And if so is the performance alot different to the standard .
Thanks in advance for any help.
http://translate.google.com.au/translate?h...l%3Den%26sa%3DG
plus FUJITSUBO exhaust system .
https://www.sau.com.au/forums/topic/238943-v35-increased-performace/
best to check out the v-series skyline section. a large portion of the stuff here is more RB related than VQ.
however any general induction and exhaustion mods will reap good gains as most cars come with restrictive systems from factory.
Thanks for that , where is the v-skyline section ??
I believe the standard exhaust system for the VQ engined cars is pretty good from factory, limiting gains for aftermarket parts.
No there not very good at all, exhaust and headers will see good gains.
On the induction side of things all the jap tuners seem to stick with the factory airbox, panel filter and a 350z intake tube, where as the yanks all swear by the JWT pop charger (pod air filter with cold partition.
Personally i think mine went a little better with it on.. ill hopefully be doing a back to back dyno on tuesday should be interesting.
A computer or unichip with a good tune will also see good gains.
I saw some pretty good gains with my catback on the Z33 just by itself, equal to when I did the extractors and cats and had my Unichip retuned to suit. The catback was a lot cheaper to do, though.
The Popcharger is great for noise, but does sweet FA for power from what I could feel. You're better off with just a drop-in K&N filter, performance-wise.
Hey alan,
Just had mine on the dyno again with the pop charger on this time and a different exhaust and im 10kw's down across the board. The exhaust change went from cannons to tri-flows at the rear the rest remained the same, headers to 2 1/2" pipe, highflow cats and x pipe. Might look into a brand name exhaust down the track, i still hate the exhaust note currently, it sounds like a bloody honda... and i would like that 10kw's back...
Fark, that sucks. I'd want that power back too - its not like we started with that much.
I heard a Fuji catback on mxfly's Z33, and I really like that note it made. It had a distinct turbine-like sound to it, kind of like Holden V8s do. It sounded really good.
I don't know what he was running north of the catback, since the car was being returned to stock for sale, but it wasn't particularly loud either.
Hey guys, I THOUGHT I WOULD POST THIS UP.... im still under the cloud wether to go f/i or keep the vq as a N/A breathing machine...
After hours on the net browsing different options, ive come past this, its still preety new in the states and not many guys have done it yet.....
The main problem they are finding is that this set up genreates alot of heat -though a simple custom airbox could do the trick like the one below found in on an alfa(pictured below)...... i know F/I is the easiest way to get horsepower... though the N/A sound is one that i cant just let go of.. especially after i get these tomei headers...
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
