Item:
A. R33 GTR RB26 stock coil cover and timing cover, coil cover is perfect, timing cover has a few marks and has fresh satin black paint.....would be good for polishing, or painting, or whatever.
B. R33 GTR Genuine Nissan 400R clear front indicator lenses, perfect condition, these go for about $130 each usually on nismo.com.au
C. Apexi EL2 Boost guage, mechanical, perfect condition, the mounting base has been bent to suit where I wanted it, but could be reshaped easily, all wires and lines are included.
D. Trust GREX gearknob, suit Nissans, blue h-pattern sticker on top, nice knob to drive with
E. Lightweight wheel nuts, set of 20, black, some marks and chips, but a quick coat of paint would fix that, extremely lightweight, came with my Volk TE37's that were on the car when I bought it.
Age: all less than 12 months, except covers
Condition: as stated
Price:
A. $120
B. $150
C. $120
D. $50
E. $50
To Fit: GTR's or whatever an RB26 is in, or any turbo car or Nissan's
Contact: PM
Comments: none.
Sorry, my mistake the wheelnuts aren't quite so light weight, they are lighter than normal, but not like RAYS or anything, however they are a full set, with lock nuts.....drop to $20 for the full set.
Knob looks like this one
RB26 covers are sold and gone.
The wheels nuts/locknuts are not the lightweight ones I thought they were, they are just a basic set of black nuts, they are lighter than normal, but nothing like the lightweight RAYS nuts which are rediculously light....no pics, they look like wheelnuts, and I have reduced the price to $20 for the set.
Covers are sold.
Edited by QIK_GTR
ill take them. pls pm me your pickup details...
pics plz
pics of what? The boost guage or the clears or both? The boost guage is a regular black faced, Apexi EL2 boost guage and the clear fronts are just clear version of the stock orange ones, I can get pics if you really require them to see what they look like.
Have you got the black indicator plate for the standard GTR front bar?
No, they are just the clear lenses/housing that fits into the black plate.
Guage is sold.
Clear front indicator lenses/assemblies left to go, someone must want these, ditch the ugly, old, mid 90's orange things and go clear.......
Lenses $120 posted, want them gone, last thing to sell, these are genuine Nissan clears, worth more than double my asking price!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
