Hey guys, just trying to sort out the little things that annoy me and my main one is oxidation on the windows that give it a bubbly look. Its only on the surface and just wondering if anyone else had this problem and how'd they fix it. Just need to know if it has to be done professionally or is there some sort of abrasive cleaner that will clean it off.
Much appreciated if anyone has any ideas.
https://www.sau.com.au/forums/topic/239343-oxidation/
Haha yeh have tried that but didn't work unfortunately. Also tried cleaners like windex but that doesn't work either, might have to have hit and miss with other cleaners. I'll try and take photos of what it looks like but don't think it'll show up too well. Its just one of those annoying things u could live with but because I want everything perfect on this car it is annoying me knowing that its there.
https://www.sau.com.au/forums/topic/239343-oxidation/#findComment-4181525
Hi Mark,
If you are refering to those water marks then I have the same issue on both my 35s. Pisses me off to no end! Most visible under bright sunlight. I've tried a few different polishes, turps, metho etc...nothing has worked so far. Someone on the forum has recommended Meguiars Diamond Cut. Haven't got around buying it yet to try. If you find a solution let me know.
Cheers.
https://www.sau.com.au/forums/topic/239343-oxidation/#findComment-4182477
Back on subject, I would suggest that you get the opinion from a Car Windscreen installer, there are some lightly abrahesive 'chemical based cleaners out there and they can buff the window too...
That should lift most blemishes.
Edited by Stephen Thorpe
https://www.sau.com.au/forums/topic/239343-oxidation/#findComment-4183451
Try AutoGlym Car Glass Polish
http://www.carcareproducts.com.au/product/...ar_glass_polish
I used it on my Lexus IS250 windows when I saw it had like dried water droplets etched on the windows... worked wonders.
https://www.sau.com.au/forums/topic/239343-oxidation/#findComment-4183652
Just tried the Autoglym car glass polish with no luck. Looks as tho it may have to get done professionally.
LOL! I tried Autoglym as well bout 1/2 an hr ago...no dice :ermm: All it did was made my glass really smooth...damn water spots still there...
https://www.sau.com.au/forums/topic/239343-oxidation/#findComment-4189916
like i said the marks r probably caused by acid rain, which has "dissolved" a really really thin surface layer of the glass... the only way I heard to remove this is using a steel wool to lightly polish the glass, so u can "even" out the layers. Again, i've never seen this done in real life, and personally I dont think steel wool + glass is a good combination.
https://www.sau.com.au/forums/topic/239343-oxidation/#findComment-4191018
Glass can be polished but not like that... Steel Wool is a big no no in my opinion.
See a professional.
https://www.sau.com.au/forums/topic/239343-oxidation/#findComment-4192353
  • 3 weeks later...
    • Photo quality is terrible, but there's a few things on that board that give me suspicions it has some issues. Add to that, I'm hoping the cut and exposed wires under the dash were not exposed or touching each other before you pulled that all apart.
    • Stories like this are why the immobilizer installs I've done are 100% reversible. No harness cuts.
    • update; Replaced oem starter motor with a Jaylec 70-61111 car still didn't start, moved over to the alarm system unraveled the spaghetti checked the solder end points, PCB board burn smell, wiring ends, capacitors, water damage everything looked fine restarted car vroom. restarted 5 to 6 time over an hour started put every thing back together only to not have it start any more. looks like i will be removing the alarm system next weekend.
    • Lots of people. Could be a lot of things like people have said. Either the heater hose/pipe, the turbo coolant return that wraps around the back of the engine, or a core plug. I have seen all three. If you want me to guess wildly though I would bet it's one of those hoses for the turbo coolant return. Or the brazing/welding for the Y- section has failed. Get a borescope down there to be 100% sure.
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
