Extra stroke volume seems to help up the top, but the GT-RS's stroked wake up alot more than 2530's stroked. Mind you though if you ran 25pound through 2530's you expect the same sort of power as the GT-RS.
That's more the tune and everything else. stroker should bring on ALL turbos quicker... smaller they are the faster... so if its not matching then the setup is missing something... or gearing is different etc etc
So I've recently replaced my old HKS 2530'S with the GARRETT 2860'S-5. I was instantly impressed with the low down power.
Re: the increase in low down power, are you talking about how the car feels when you drive it, or the graph shape?
Why did you change turbos?
Car is making a shitload more power in the lower RPM range opposed the 2530's IE 20pound at 4k opposed to 5k. My rear 2530 bearings failed so I decided to purchase the garrets because of the cheap price and also rebuild both the 2530's to new spec
And they have been rebuild now and are ready to put back on but I prefer the 2860's.
Clint.
Clint.
did you take the sump off and clean it out? The ball bearings in the core assembly fall down the drain tube upon bearing failure and end up in the sump. These balls are small enough to pass through the oil pick-up gauze and end up making a mess of the oil pump (shattering the gears into several pieces).
Hey Brockaz..
Dont suppose you have a sheet with 2.8 with 2860's, like Gavs later combo.
I only have his initial run, which only made about 500hp and finished at about 7k.
He has another chart where he's made 550hp and revs out. Thats the only one worth putting in that graph.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
