Who's Interested In a Drift Day SAU Only BBQ? Give us some Numbers.
Subject says it all .... :)
We Need numbers of who's interested. :D
Steve:
BYO
BBQ is in the car park, we have to get in and park off a section
Breakfast at 9
Drift starts at 10
Lunch time BBQ
And as many beers as you feel appropriate in between and after
BBQ is free, but if you want to donate a beer, or bring something along feel free.
Covered so far is:
Eggs, bacon, assholes, snags, onions, bread, sauce and oil
BBQ (T-man, you have a table for prep?)
BBQ tools
  • Replies 88
Finally got the good oil.
All food is ok, snags are in, rissoles, eggs, bacon whatever - so maybe rissoles, eggs and bacon for breaky, onions, snags, rissoles and eggs for lunch????.
BBQ is only allowed in the car park, so it will be a case of find somewhere up wind, park cars to section off an area and bbq on.
This is cos the park are doing a sausage sizzle during the day.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
