Hi guys
Well, went through regency the first time and I got 2 bloody pages worth of things to do to the car, to clear the defect. :banana:
If I had the time I would probably do everything myself, but I want the car on the road asap,
So, I was wondering if anyone know of a workshop that can do this type of work, maybe if you have had good experiences preparing a car for regency with them or something. Might need to borrow a few things off them as well, so hopefully someone that has all the stock gear for those situations.
Its nothing major, just lots of annoying little things here and there...
Cheers
https://www.sau.com.au/forums/topic/239607-workshops-for-regency-stuff/
SMOOTH GARAGE!!!! i couldnt recomend them enough and they will hook you up no prob. plus regency is just down the road from their place.
there is another place on main nrth rd, but they are WAY to over priced and everytime ive been there ive left with a bill of over a 1k :banana: so i wont even say their name haha
i wasnt going to say their name but owell.
its a shame that they are so overpriced because they do decent work and are a great bunch of people! i just cant afford to go their anymore and come out over a grand less everytime for such small things!
The infamous list:
- Horn to operate (need a steering wheel that works)
- Number plates lights (rear)
- All lights to operate
- Pedal covers to be rubber (not aftermarket.)
- Tighten front seat belt buckle
- Brake fluid level low
- Replace left indicator (broken)
- Repair rust through battery tray+skirt
- Brake hoses to be secure (need some hoses that come with the fittings that go on the clamps)
- Remove rose joints on all rear suspension + front torsion bars (fit stock gear)
- Replace LH engine mount
- Replace split rack boots
- New Gearbox rear mount to be fitted
- Rectify brake fluid leak LH front hose
- Fit split pin to LH rear lower joint control arm
- Replace worn lower shocker bushes on rear shocks
- Rectify free play LH rear wheel bearing
- Engineer Hicas lock bar as well as rear lower control arm mount (been welded back to crossmember)
I can do a few of these things, but the ones in blod I want done by the workshop.
I am waiting on a quote from smooth garage, boostworx....well I dont have 5 weeks to get in, I want to do it next week.
Any other ideas?
Cheers guys
The infamous list:
Any other ideas?
Cheers guys
Holly crap dude
the guys at regency really did write out a novel on you
goodluck with it all
Take it to Shuan at Boostworx. What's on the sheet? Maybe you could do some of it at home.
+1
Shaun is a nice bloke.
go to the site and send them a Email.
im going to boostworx wed with a list not as long as yours but alittle worse
alot cheaper than jms etc.
good luck
Edited by PREISS
hey mate,
we do this kind of work all the time, we just finished a very major defect on a customers 300zx
we have all the stock parts on the shelf so thats no problem, we can even take the car to regency and get it passed :)
if your still looking for a workshop to do the work let me know and il do my best to help you out
cheers
Steve
Edited by Nisswreck
$250 to issue a certificate for a Hicas Bar??? f**ck that!
Looks like Smooth Garage are going to take care of it next week.
We will see how that goes.
Well that answers the question I was going to ask so you can't have a hicas lockbar without it being engineered. Who did you get the quote from for the HICAS lockbar certificate? If its that much I may as well swap mine back to stock to clear defect and swap back afterwards.
I got that quote from Rory Thompson, they are real arseholes there, put the car in the hoist for 5 mins to have a quick look, I said I was going to think about it and look at other options, and he goes "just give us $30 for our trouble" :)
Yes you better put the stock back on to be safe.
hey mate,
cheers
Steve
PM Sent!
going by your list a lot of the stuff listed it should have been kept on top with if the car was mainted to a reasonable standed .
ie how can you drive and not know you have a broken engine mount things like like oil leaks .
lights not working worn shocky rubbers surley they must have been knocking a bit ?. not meaning to be rude but i see cars like this every day where i work what makes your skyline any better than a vn commy with the same probs .
it may be a blessing in disguise you got pulled over at least you will have a safer car all round when it;s fixed
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
