Finally It Gets Thru Compliance And Is Tucked Away At Home
  • Replies 56
Now thats one HOT ride!!!
And your questions?
My question..
whats the spec's of the car mate??
cheers
I wanted to take some more pictures, including of my questions.. :P but so far they are
a) after an hour on the road the back of the car emits a quiet but annoying squeak.. squeak..
over bumps, eg the damn pacific highway north of coffs. doesn't seem to happen
when cold.
b) does anyone know a great mobile detailer guy, who loves black, in sydney?
c) Should the fuse box in the engine bay have a cover?
d) does every gtr have little dash rattles on bumpy highways? I've got a couple but won't
go hunting for them if thats just the way things tend to be? like, coming from behind the
dash, or air vents there are these little scratchy ticky sounds over bumps. My other car
is a golf and its solid and tight, so maybe I'm expecting too much of a vintage car.
e) the biggie :D The gear stick has what I imagine was very shiny looking aluminium with the
GTR logo but it is all tarnished. If this is a stock gtr gear stick, is there a stock cleaning
product people use on it?
f) when I open the door(s) they don't hold open they just swing as wide as you like and on
a camber will shut again. The door arm looks like it has outdents on it, which i can just feel,
is that something that can be tightened up or is it just the way it is?
g) there is a clutch rattle in neutral that goes away when I put my foot in the clutch.
Do coppermix twins rattle? I remember reading they don't. Is it the flywheel perhaps?
it isn't enough for passers by to think there is a problem but it is there.
h) it idles at 1200 indicated, is that about right? very smooth but seems high.
i) the speedo reads 10% over. I'd rather it read right, is that tweakable?
specs, well, I'll take it somewhere to check it out see what it does on pulp.
it has a nismo ecu, n1 block and all the nismo r parts... an R1 conversion with the
omori plate in the bay (nismo still have the goodies list up somewhere). S tune
suspension and the weldina exhaust which has a lovely popping on the overrun..
your answer the question g.
i've had twin plate and i've got a triple plate clutch now and they both rattle when the clutch isn't in.
the only way i could tell the difference is the twin plate i found was really snappy(on of off), where as my triple plate is softer and it can be ridden slightly before it engauges.
nice car man congrats.. mine's no GTR but i have one annoying rattle like the one you describe.. over it... and the door thing i think it's called check plate. you need new ones.
umm....
A - Dont know
B - Jet Detailing - Actually, I dont know if he is still in the game, Jason is a member here also!! JETr32 or something?
C - Yes
D - Compared to the newer golf, yeah it would rattle!! Mine rattles, mines an older r33 nugget!
E - Dont know!
F - again, dont know haha
G - Already answered!
H - Does seem a bit high
I - I thinm most speedo's read a bit higher. I'll be sitting on 110 on the freeway from the speedo, and the powerFC shows 105 or so.
Sounds like an awesome car!
Enjoy it mate!
thanks for the answers so far.
Any idea what this is? It appears to have been connected recently. If I was to reconnect it,
where do i go hunting for the big 3 connector plastic block, to plug it back in again?
when cold.
During braking, accellerating, cruising....where does it do it?
Yes. Get one now.
All cars do it mate, my Stagea was the same because it used to rattle and buzz whenever I travelled down rough roads - it was worse in my car also because I had Tein Coilovers which were fairly firm, your teeth fillings would fall out if you hit a big bump.
e) the biggie :) The gear stick has what I imagine was very shiny looking aluminium with the
We'll need pictures for this one but i'd suggest you rock on down to Supercrap Auto and get some Mcguirs metal polish for the gear knob and surounding console. :)
1200 does seem a touch high, should be around the 800 mark. Try resetting the ECU by leaving the battery D/C'ed overnight. Failing that - (GTR owners!) Does the throttle body have an idle adjust screw?
I wouldn't bother - if you're going slower than your speedo suggests atleast you'll know you won't get done for speeding any time soon. :(
Overall it's a very nice example, i'd still be happy with it regardless of its discrepancies. ;)
G i got a rattel squike on clutch. and stops wen u put clutch in i went 2 toy shop. and they said something but cant rember but if it get worse sort it coz it apparently will do cincromesh in gear box
The "rattling" sound when you've got the clutch disengaged sounds like the common thrust bearing/gearbox noise.. Nothing to worry about if its more of a grinding noise - its fairly commmon.
Very nice car by the way!
Great thing about Nur Specs, there's very little you HAVE to do :P
Some new wheels if you feel like a change
might look at a more solid strut brace too
Mostly just upkeep. It's already modified quite extensively from the factory :banana:
You might want to look at a sound system that works in this country, the only other Nur I have been in has GPS that likes to think we're driving in the middle of the ocean...
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
