Weird Issue im having...
Left Indicator turns on slightly (Basically it a very dimm blink) when Right Indicator is active. It doesnt happen if I turn on the Left indicator. Only if I turn on the Right Indicator.
Any ideas?
Rob
https://www.sau.com.au/forums/topic/239831-indicator-problem/
