Toyota:
Cresta:
Body 90k, Engine 60k:
5 speed Manual:
White:
Craigmore SA:
Complied in QLD rego and transferred to SA
not regoed atm, but can be
$5000 firm
Contact:Ryan 0413639388, msn: [email protected]
Started at a stocker, spat a rod, dumped my 1ggte from my supra in it. has a gt35r strapped on, bosch motorsport 023 FP, emanage etc. well sorted, needs injectors and tune to make more power. currently tuned safely on 8psi makes 142rwkw with restictive exhaust. Needs some lovin i have no time for it. Interior is mint and complete but not all in, intrument cluster is out of supra, needs better fitting. I've spent 15k on the engine so this is a steal for a drift pig or tidy up and use as quick daily
Pictures on request
thanks guys
Ryan
https://www.sau.com.au/forums/topic/239893-cresta-for-sale/
is also on carsales now
http://www.carsales.com.au/used-cars/priva...Nne=20&Make =TOYOTA&__Ns=pCar_PrivateSpecialFlag_Int32|1||pCar _ImageCount_Int32|1||pCar_LastModifiedDate_DateTim e|1&__N=4294962861%201216%20834%20285%20257&distan ce=10&silo=1003&seot=0&__Nf=p_GeoLocation_String|G CLT%20-34.71198%2c138.7382%2018.0&Cr=10&__No=60&trecs=82& __sid=11D921F639A9
Ryan
https://www.sau.com.au/forums/topic/239893-cresta-for-sale/#findComment-4260337
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
