STAGEA CRUISE THIS SUNDAY 19TH OCTOBER @ 12.30PM
Cruise this Sunday 19th @ 12.30pm. Meeting at Kell's meet spot. If you have no idea where that is, PM me and I will let yas know.
Maps for the trip will be handed out on the day, but will basically involve cruising from the city to Strath for lunch via the tunnels/freeway, back thru Glenelg, with the final stop being back at the meet point.
Can I have people who can attend put their hands up so I can print maps/directions.
:P
  • Replies 81
through glenelg take a squiz at the SAU cars who are entering Small Car Sunday :D
Thats a little bit of the plan I had :)
Get a bunch of Stageas cruising past a car show to grab the attention :P
I would love to come out but ill have to see if im working. I missed the post in the other thread that said when it will be and didnt put it on the roster. Ill see as theirs a slight chance ill get sunday of to recover from a bucks night on sat.
I'd love to come but my father inlaw is getting married so I'd have to wriggle my way out of that... shouldn't be too hard, yeah hell.. pm the meet point and I'll come. but I gotta come from victor so I might depart from strath and head home.... long way back to adelaide just to drive back through strath.
I reckon I will... So I guess I better get the silver bullet washed and shiny again!
haha - Ive been meaning to wash it for weeks.
Edited by Unbalanced
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
