You can set the fan temperature turn-on value to below lower then 60deg.
http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#23
I read it in paulr33 power fc faq!
How can I turn-on the fans from ecu?
From where I can take 12V or ground to turn-on the fans?
Also how can I adjust from power fc the temperature that I would like to turn-on the fans?
Since now I turned-on them from a fan controller.
https://www.sau.com.au/forums/topic/239963-fans-turn-on-from-power-fc/
Sorry I am from Greece and I don't know your timezone..
The 6 wire in ecu says "Sub electrical fan relay (engine temp switch)"
If I connect the relay from my fans there?
It sends 12V or ground?
At what temp start?
How can I adjust it?
Or it isn't the right cable the PaulR33 know and say that we can adjust the start temp?
If you have the PowerFC cable and software or the datalogit kit you can get to a few features that arent supported on the hand controller.
# You can download maps to your PC and save them.
# You can set the fan temperature turn-on value to below lower then 60deg.
# You can set the millisecond values for the engine flash light for AFM, INJ, KNK levels.
# You can access and control the air temp correction table.
# You can adjust load map points by extended the airflow measure levels.
Do you have the PowerFC cable and software or the datalogit kit ?
I don't have it.. but my tuner have it.
So please tell me what to say him to do and in which wire to connect the relay fans please!
Without doing something with the software-datalogit, at which temp will open the fans?
But the most important is to tell me in which wire I must connect the relay please!
Edited by GreeceS13
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
