well, as the title says,
i sold the 33 today
some 20 yo bought it. 13g cash
hope he looks after it as well as i did,
judging by the way he drove off (even in low-boost) it aint gonna have a good life imo
ahhh well, life goes on, time to start looking at my new home.
https://www.sau.com.au/forums/topic/240011-my-babys-gone/
  • Replies 66
yeah im not gonna say much just in case he comes on here,
but, you know..........................
na damo, new house first mate, may even take extended mortgage for 34. gotta see what the boss (gf) says
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192055
I'm with you mate ... investing in property first. Car second. :P
Hope the mortgage goes well. Once your on top of it, extend it and get a 34 :)
very much agreed, altho with current "economic crisis" im almost tempted just to keep spending on the current car lol
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192118
same, once the housing prices come down a bit i may be inclined to purchase an investment property, probably take an extra 20k on the loan to pay off my car loan so just the one payment comes out. Better start saving :P
Edited by Damo_R34
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192124
i sold the 33 today
:P so he drove it just like you did :wink::)
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192329
cheers all :)
its good to have that extra boost in house deposit,
and with no car expenses, ill be saving soooooo much money!
so its a blessing iin disguise really, hasnt really sunk in yet though :)
wait till summer nights when your all out cruising :blink:
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192565
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
Ă—
Ă—
