well, as the title says,
i sold the 33 today
some 20 yo bought it. 13g cash
hope he looks after it as well as i did,
judging by the way he drove off (even in low-boost) it aint gonna have a good life imo
ahhh well, life goes on, time to start looking at my new home.
https://www.sau.com.au/forums/topic/240011-my-babys-gone/
  • Replies 66
yeah im not gonna say much just in case he comes on here,
but, you know..........................
na damo, new house first mate, may even take extended mortgage for 34. gotta see what the boss (gf) says
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192055
I'm with you mate ... investing in property first. Car second. :P
Hope the mortgage goes well. Once your on top of it, extend it and get a 34 :)
very much agreed, altho with current "economic crisis" im almost tempted just to keep spending on the current car lol
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192118
same, once the housing prices come down a bit i may be inclined to purchase an investment property, probably take an extra 20k on the loan to pay off my car loan so just the one payment comes out. Better start saving :P
Edited by Damo_R34
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192124
i sold the 33 today
:P so he drove it just like you did :wink::)
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192329
cheers all :)
its good to have that extra boost in house deposit,
and with no car expenses, ill be saving soooooo much money!
so its a blessing iin disguise really, hasnt really sunk in yet though :)
wait till summer nights when your all out cruising :blink:
https://www.sau.com.au/forums/topic/240011-my-babys-gone/#findComment-4192565
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
Ă—
Ă—
