Hi,
I did this for both our cars a couple of years ago when I moved to Adelaide, silly me really as it was much cheaper to leave them registered in WA. I digress! All I needed was the rego papers from WA, went in and changed them over to SA....the cars didn't need to be inspected at all.
Cheers,
Matt
  • Replies 75
Posted Images
Btw, guys you can get Krispy Kreme in Adelaide...
http://www.sensational-adelaide.com/forum/...it=krispy+kreme
I read this topic several times and havent found anything that would indicate that krispy kreme is in adelaide...
Im not 100% sure, but I believe if you owned and registered the car (in your own name) interstate and move here there is no need for an inspection, just visit a motor reg office and pay for SA plates and Rego sticker.
check out http://www.transport.sa.gov.au/registratio...icles/index.asp and give an office a call to confirm the prices (may be cheaper to stay with NSW rego, but RWC will be a problem unless you go back for a holiday).
Unless you hold a current interstate registration certificate in exactly the same name as the intended South Australian registration, the vehicle must undergo an identity inspection to confirm the correct identity of the vehicle. The vehicle can be inspected at the following inspection stations upon payment of the correct fee .
and
If you live within a 40 kilometre radius of the Adelaide GPO , the vehicle must be inspected by the:
Vehicle Identity Assessment Station
7 Naweena Road , Regency Park 5010
Open: 8 am – 4:30 pm, Monday to Friday (except public holidays).
No appointment is necessary.
If you live more than 40 kilometres from the Adelaide GPO , you may have the vehicle inspected at
* your local police station.
Please contact the police station to arrange an appointment.
or
* Vehicle Identity Assessment Station
7 Naweena Road
Regency Park 5010
IGA North Terrace... i've ordered from them several times now. :)
IGA North Terrace... i've ordered from them several times now. :(
I just rang them and they said they dont do KK's -
My wife loves KK's and I thought if I get her a box of KK's I might get a box myself. :)
Edited by 4door_Sleeper
They said that? lol Maybe they're not suppose to be selling them and are playing it safe.
Anyhow.. the idea is to go in put an order down.. (they need orders in by thursday), and the arrive on monday for you to pickup.
Hasn't been on Dyno yet - just finishing it off now.
Which is why I don't really want to sell it and get something else if/when we move - It's been in the workshop for ages and I haven't enjoyed it yet ! Plus, I have spent heaps on it - Well not heaps - but I won't get it all back if I sell it.
Yes - sure am. Got to get it back from all the mechanical first. As you can see it's muti-coloured blue/silver.
The plan was that I was going to spray it myself with the help from a mate who knows what he is doing.
But if I come to Adelaide, the girlies cuz is a spray painter - COOL !
thats bloody sexy
only thing i'd add is our city seems to have a disproportionate amount of scumbag car thieves... make sure u get a place with a lock up garage, have an immob + alarm, club lock, and a sensor light/german shepherd wouldnt hurt either.
You think I'm joking. I'm not. :)
-D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
