Skyline V- series and 350Z Meet and Greet Sausage Sizzle fest
Date: Sunday 30th November 2008
Time: Sausage Sizzle to begin at 12.30pm (staff and event co coordinators will be there at 11am)
Location: Bodyform Motorsports Unit 5, 46-48 Jedda Road Prestons NSW 2170 (closest cross st - power drill) map here www.bodyformaero.com.au
Lunch Sizzle: We shall supply Snags, bread, condiments, serviettes and drinks. Coin donation appreciated. Feel free to bring your own also.
Afternoon Cruise: approx 3pm. Depart from Bodyform > Cordeaux Dam > Home
Directions: Exit Jedda Road onto M7 (require E Tag). Heading South onto Princess Highway. Picton Road Exit. Right turn at Cordeaux Dam. NO Traffic lights!!
Behavior: This is a private car park, there MAY be other tenants using the facilities. Please refrain from any idiosyncratic driving inside the complex. Keep all areas clear of rubbish, respect other tenants property. Park in allocated parking spaces.
Also attending : HPI magazine - Motul – Giveaways – Pole Dancing Course + more TBA (V35 Driver to update)
Brief: Expect a casual fun day out, talk shop, look over some nice rides and meet various personalites. Enjoy yourselves and just grow this V series community. :wave:
Please add your name and attendees so we can cater for it.
More info TBA- we'll just get the date up for now.
Can a mod sticky this please.
  • Replies 84
Posted Images
Cruise to Cordeax Dam after the BBQ. About a 40minute drive from Prestons.
http://www.stonequarry.com.au/nature/cordeaux_dam.html
From Wollongong: take the freeway north towards Sydney, then the Picton turnoff. The entrance is about 10 minutes on your left.
From Sydney: take the M5 towards Canberra. Past Campbelltown, take the Wollongong turnoff at Picton Road. The entrance is about 10 minutes on your right.
Cordeaux Dam is open 7 days a week, 10.00am to 5.30pm. (Closes 7.00pm weekends and Public Holidays during Daylight Saving Time.) Entrance is free.
Keep the numbers coming in people!
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
