Which radio station do you listen to the most?
57 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hamish and Andy are okay ... but the morning show sucks dog's balls ;)
i'm never awake for the morning show haha, but through out the days they have little snippets
and well yeah LOL, Amber's voice annoys me she sounds like a man :kiss:
we have nova on at work, seems to be a good mix and not too many ads, i just get sick of the talking
we had fresh on awhile back, some good tracks every now and then, but so damn repetative day to day.
i like jjj, cos im a fan of local/aussie music, but not the hiphop though
i listen to mix and tripple m, cos i like a lot of the older music compared to what is released these days
safm is a never for me, cant stand it full stop!
Didnt you have mix 102.3 playing in a pic a while back SAM?
Radio in town is shocking, how many times can they play a shit pop song in an hour? give me DVD,1 terabyte HD juke box, or internet radio from LA with good hard rock on it or hiphop piped in thru a wireless connection using a old laptop, radio is good for a laugh , a pethetic one at best..lol
pretty bad when talkback is better then safm...lol
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
