Flute or Canon exhaust tip?
78 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 103
mufflers are for girls lol. Nice exhaust Nisskid, wish I'd thought of putting an angle on mine when I got my mate to do it. Btw how can you drive that on the street without scraping it off / attracting much attention!?
Edited by bozodos
btw, 3" straight through
dude do you have a big pic of that, and the one a page back where you're sideways?
i must say your car is porn!!! :D
and yeh pipes are the shizz!! might drop in to et on friday and get a quote on some twins :P
lol, well since its near the rear wheels its not a problem unless my wheels go each side of an object, and the object goes down the middle of the car. as far as attention, well, lol, being an RB20 its not obnoxiously loud, its a very smooth sound, i also run a ECV with it, which helps to an extent. usually i run my JunBL exhaust for the street though, which as i mentioned used to have flutes, but have been grinded off and will be replaced with twin 3" pipes, should be a bit quiter, as to be honest, for a street exhaust its quite loud.
i have been pulled over before with the straight through 3" tho, was an interesting conversation, luckily i was already on defect and had clearance to drive it, so technically there was nothing they could do.
i think his words were something like, "does this even have a muffler, wait.. does this even have a cat?" :D
haha i think ive got a bigger one somewhere, ill get some pics up of my new track exhaust once ive completed it, as i mentioned it will be using cut up versions of the flutes off my street system, it will be straight 3" piping from the dump, split into 2x 3", then the flutes go from 3" to 4"
personally i dont think it will look as good as straight pipes, but it will give a bit more volume, and on the track, especially in battles u want as much as u can get. nothing worse than not hearing ur engine over the guys next to u.
ahh sweet as... im doing mine for track too, gonna keep the cannon on for street as its fairly quiet and does the job fine. was thinking of getting a screamer made up for track too but its gonna be a pain in the ass having to change it over every time i head out.
you getting yours made up out of mild steel or s/s?
Edited by SkyHi_33
I was thinking along the lines of speed humps etc!
Haha yeah I did get defected for having a straight pipe once but the cop decided my blow off valve was more important, which is incidentally why you can see a flange after the bend on the pic I posted, so i can swap a Super Dragger muffler in for RWC.
I've decided now that I'll just get a whole legal exhaust though for RWC, rather than keep chopping and changing bits all the time!
race cats ftw too!
meh, nothing wrong with the screamer for street, just dont drive hard around suburbs. i run mine on the street, i also have a little attachment which i can put in that plumbs back the screamer which i use for regency, so i dont have to swap over the whole dump.
the exhaust im making will be out of a mixture of high grade s/s and lower grade s/s.
race cats ftw too!
i dont really go over many speed bumps lol, i know where they are usually and avoid them at all costs. but because the lowest point is under the rear wheels its fine. the rest of the exhaust if anything is higher than a standard system as it doesnt have any mufflers.
ahh fair enough, yeah I had to get both my mufflers removed for RWC because they sat too low, but then the exhaust was too loud (gotta love NSW and the annual RWC checks). My whle exhaust, which used to be a Fujitsubo before being butchered, sits barely 100mm off the ground! I don't get scraping at all though, which is why I never have put my coilovers to their lowest setting.
I've emailed Exhaust Technologies about the flutes though, otherwise I'd probably go twin 2.5" on an angle, cause straight pipe looks shite!
Dude go to twin 3" on the angle. I wanted twin 2.5 after seeing nisskids single pipe pics awhile back and thinking that twin 3" would be too much. I thought about it for awhile then decided to put my balls back in and get twin 3" anyway - now im glad I did cause they dont look that big once on :)
yeh twin 3" is alright, personally id rather for 2x 2.5" for the street, but ive got about 4-5 meters of 3" stainless here and no 2.5" so choice is pretty clear lol. but i think the 3" will look better, just stick out a bit more for the boys in blue.
btw u got pics of the twin 3"? is it straight or angle cut? was thinking about a tiny angle cut on the edge.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
