i was out n about all that night... forgot 2 post as well, monday arvo bout 3:00, all at erina... spotted 1 black silvia or 32 with no wing n nice mags at the big set of lights... a silver 32 pulling out below the 7/11... n a stock but really nice looking yellow 34 gtt with wing going past the woodport
spotted WLD25T at cardiff yesterday around 3 3.30pm
That thing is always in Cardiff. It just sits in slightly difference spots all the time because it's for sale.
Atleast it looks better than it did. I beleive it had a Veilside kit when it was for sale in a car yard at Edgeworth.
Also I spotted a Grey or Black R33 in Cardiff (Cardiff Toyota Intersection) at around.. 8:00pm-ish.
spotted dark blue 32 at nelson bay today..... only skyline i have seen apart from mine since i been here from sunday.
are there any/many skylines in newcastle??? many ppl look at me like "what type of car are you driving"
the closest car i have seen that looks modified is the police cars, and 1 mirage with an exhaust if that counts, im guessing there isnt much of a car scene in newcastle........
spotted drews okokok 34 gtr with sum cool lookn kid driving it into gossy last night... did i mention he was cool? :D
spotted a cool lookn kid in a 34 gtt pearlescent pearl drift spec machine cruisin round the freeway on saturday night.
Friday night spotted a nice looking white R34 fellowed me from lisarow to wyoming ...... it also sounded nuts
spotted a silver R33 at wyoming
spotted a nice clean white R33 going thought wyong
The white R33 might of been me. I was between Chittaway/Watanobbi a few times friday night.
I spotted a silver r34 gtt on tuggerah straight near autobarn saturday
Also a black r32 gtst at wyong on sat.
was it white with an ex gate?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
