I spotted a white 34 which I waved (he waved back) on Myall Rd yesterday, could be the same one?
Also spotted you on Park Avenue yesterday James, you surely saw me :) ?
haha yes yes i did see ya :D , yer probably was the same one.
Also saw a purple 33 parked near maccas at warners bay looked very neat.
And another i saw rh9 plates on some lil 2 door kia or something? is this just a coincidence or rh9 swap plates to a different car :) ? hehe
^ Didn't see you...
you wouldnt of seen me , i was in the sonata * daliy driver* due to the fact my car is still off the road :)
Edited by BB81DO
i spotted Oo.34.oO again pulling into the shell servo gosford. heading towards the freeway, police saw him then turned around infront of me, nearly cleaned em up...
omg i didnt see the coppers :( was that the paddy wagon??? awww i didnt see u where were u ???
lol yeah was the paddywagon, i was going the other way but i was in a navara with a vertex kit hanging out the back of canopy and the rear windows haha
and i saw you AGAIN tonight, i was in the 32 this time though, i saw you at last min so couldnt beep or wave but i think you looked not sure
Ah yep that'd be the one, it was parked right opposite to Frontline. Looks clean.
I nodded a guy just getting out of his Maroon R32 GTS-t coupe in the Glendale centre carpark today around 1pm. Got a nod back :blink:
13:00 2day gave n got a wave from a lady in a white s2 33 gtst near the green point erina lights
later on cruised with a silver 33 gtst with a gtr wing thru erina, got the nods happenin n all
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
